Problems with Pressure boundary condition in a compressible steady case |
August 26, 2024, 03:04 |
Fabian
Rep Power: 3 |
Hello everybody,
I am trying to set up a case of a pipe. The inlet is a totalPressure boundary and the outlet a static pressure boundary. I am using the rhoSimpleFoam solver since I want to get a high pressure difference in the end. Until now the pressure difference is set to a low value because the simulation does not converge even with low pressure differences. The simulation stops (depending on the settings) after around 30 iterations. Setting up the simulation with a mass flow inlet works perfectly fine. As far as i can tell the error occurs at the inlet. Here the velocity close to the wall is very high compared to the rest of the domain. Can you tell me what I have to look out for when setting up compressible simulations of internal flow with totalPressure inlets and static pressure outlets? These are the boundaries: p: Code:
inlet { type totalPressure; rho rho; psi thermo:psi; gamma 1.3; value uniform 5000000; p0 uniform 5000000; } outlet { type uniformFixedValue; uniformValue table ( (0 4999000) (5000 4999000) (20000 4900000) (25000 4900000) (250000 100000) ); } "(?i).*walls" { type zeroGradient; } U: Code:
inlet { type pressureInletOutletVelocity; value uniform (0 0 0); } outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } "(?i).*walls" { type noSlip; } T: Code:
inlet { type fixedValue; value $internalField; } outlet { type inletOutlet; value $internalField; inletValue $internalField; } "(?i).*walls" { type zeroGradient; } Initialization: p: internalField uniform 4999500 U: internalField uniform (0.1 0 0) T: internalField uniform 293.15 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
UDF for Automatic Solution Initialization for previous case data file | gartz89 | Fluent UDF and Scheme Programming | 6 | March 30, 2020 07:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
