Switching from k-omega SST to k-epsilon/Spalart-Allmaras |
August 24, 2024, 07:37 |
Ilyes SAYAD
Rep Power: 5 |
Hello FOAMers,
I’m currently running a CFD simulation of a wind turbine using the k-omega SST turbulence model. I’d like to switch to the k-epsilon and Spalart–Allmaras turbulence models, but I’m unsure about the necessary modifications to the "0", fvSchemes, and fvSolution files. I’ve attached the case directory for reference. Thank you in advance for your assistance ! Best regards, Ilyes |
August 25, 2024, 12:34 |
Ilyes SAYAD
Rep Power: 5 |
Hello FOAMers,
I've successfully run a case using the Spalart-Allmaras turbulence model, thanks to Gabriel Felix's tutorial—much appreciated. However, I'm encountering an issue when switching to the k-epsilon model. When I run the simulation with pimpleFoam, it crashes right at the beginning due to a floating-point exception. The log file indicates that "bounding k" has reached an extremly high value of x*10^122. I’m not sure how to address this problem, so any guidance or suggestions would be greatly appreciated. I’ve attached the case and log files for reference. Best regards, Ilyes |
overshooting of Omega in SST komega using simpleFoam | cm_jubayer | OpenFOAM | 2 | June 7, 2020 12:52 |
Weird result by k omega SST | bingo641 | OpenFOAM | 3 | May 27, 2018 23:05 |
Setting change from k omega to k omega SST | bingo641 | OpenFOAM Programming & Development | 0 | May 22, 2018 05:15 |
how to calculate the omega at inlet boundary in k omega sst | Scabbard | OpenFOAM Running, Solving & CFD | 2 | September 30, 2014 13:06 |
Boundary Conditions for k omega SST | dancfd | OpenFOAM Pre-Processing | 0 | June 9, 2011 23:25 |
