Using total pressure as inlet BC for external flow past airfoil |
August 12, 2024, 21:21 |
TWB
Rep Power: 19 |
I'm trying to set up a flow past airfoil case using rhoSimpleFoam. I would like to use the total pressure as the inlet BC instead of fixed value velocity BC as before so as to validate with an expt. My pres BC at inlet is: type totalPressure; p0 uniform $p_total; for internal, I use the static P internalField uniform $p_inf; For vel BC at inlet: type pressureInletOutletVelocity; value uniform (0 0 0); internalField uniform (0 0 0); However, the run diverges almost immediately. So I wonder what's wrong. How should I set the int field for P and U? Should the outlet BC change now due to the use of total pressure? I'm using zero gradient or inletOutlet as BC Thanks |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 13:16 |
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 14:14 |
Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 15:39 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
