FOAM Fatal Error Cannot find file
Old   August 12, 2024, 15:53
Default FOAM Fatal Error Cannot find file
Paul Hammerstrom
hammerpe33 is on a distinguished road
Hi all,
I am new to OpenFOAM. I have installed OpenFOAM in windows. I am trying to run a steady state incompressible turbulent analysis of glycol through a chamber. I have created the mesh in SALOME and exported it as a .unv. I then used ideasunvtofoam to convert the mesh. When I go to run simplefoam I get the following error:
# simplefoam
| \\ / O peration | Version: 2406 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : 34e226dfe3-20211220 OPENFOAM=2406 version=v2406
Arch : "LSB;label=32;scalar=64"
Exec : C:\Program Files\ESI-OpenCFD\OpenFOAM\v2406\msys64\home\ofuser\OpenFOAM \OpenFOAM-v2406\platforms\win64MingwDPInt32Opt\bin\simplefoa m.exe
Date : Aug 12 2024
Time : 14:31:32
Host : PAUL
PID : 19268
I/O : uncollated
Case : D:/analysis/exothermics/banzyfurnace/cfd/half_chamber
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.001
field "(k|epsilon)" tolerance 0.001
Reading field p
--> FOAM FATAL ERROR: (openfoam-2406)
cannot find file "D:/analysis/exothermics/banzyfurnace/cfd/half_chamber/0/p"
From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 629.
FOAM exiting
The file "p" is there so I am not sure why it is saying it cant find it. I edited the files with notepad in order to put the correct values in.
hammerpe33 is offline   Reply With Quote
Old   August 13, 2024, 08:57
Paul Hammerstrom
Sorry I forgot to include the files:
controlDict
|  \\    /   O peration     | Version:  v2406                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      controlDict;
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         1000;
deltaT          1;
writeControl    timeStep;
writeInterval   100;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    #include "coordinateTransform"
    #include "momentum"
    #include "timeInfo"
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss limitedLinearV 1;
    turbulence      bounded Gauss limitedLinear 1;
    div(phi,k)      $turbulence;
    div(phi,epsilon) $turbulence;
    div(phi,nuTilda) $turbulence;
    div(phi,R)      $turbulence;
    div(R)          Gauss linear;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver          GAMG;
        smoother        GaussSeidel;
        tolerance       1e-06;
        relTol          0.05;
    pFinal
        $p;
        tolerance       1e-06;
        relTol          0;
    "(U|k|epsilon)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-05;
        relTol          0.1;
    "(U|k|epsilon)Final"
        $U;
        tolerance       1e-05;
        relTol          0;
PIMPLE
    nOuterCorrectors 4;
    nCorrectors     1;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
SIMPLE
    residualControl
        p               1e-2;
        U               1e-3;
        "(k|epsilon)"   1e-3;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
        "epsilon.*"     0.7;
cache
    grad(U);
Old   September 3, 2024, 20:27
jky
jay
jky is on a distinguished road
Hey! have you solved this issue? I also ran into the same error, but in my case, it is a T file. do you find any solution or thread to tackle this error ?
jky is offline   Reply With Quote
Old   September 6, 2024, 14:15
Paul Hammerstrom
JKY,
I have not found a solution. I had to move on to some other projects but I still need to figure this out. I need to finish this analysis in the coming month so I will be circling back to this soon. If you find anything out please let me know.
-Paul
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
