Floating point exception when using simpleFoam for OpenFOAM '3 weeks' series |
August 6, 2024, 10:58 |
Josh
Hi OpenFOAM users!
I'm very very very new to CFD, and have been trying my hardest to learn OpenFOAM. Thus far, the '3 weeks' series of tutorials on the wiki has been a godsend, but I've encountered a problem with one of them. Here's the pdf with all the information about the case setup: https://www.fluiddynamics.at/downloa...xample_Ten.pdf I've followed all the steps up to running simpleFoam, but when I do it I get a floating point exception: Code:
[stack trace] ============= #1 Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #2 ? in /lib/x86_64-linux-gnu/libc.so.6 #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #4 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so #5 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so #6 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/simpleFoam #7 ? in /lib/x86_64-linux-gnu/libc.so.6 #8 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #9 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/simpleFoam ============= Floating point exception Code:
Time = 16 smoothSolver: Solving for Ux, Initial residual = 0.00672444, Final residual = 0.000187917, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00620943, Final residual = 9.26625e-05, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.0153594, Final residual = 0.000618596, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0183642, Final residual = 0.00045666, No Iterations 2 time step continuity errors : sum local = 6.28939e+78, global = -1.49885e+65, cumulative = -1.49885e+65 smoothSolver: Solving for epsilon, Initial residual = 0.0864303, Final residual = 3.64626e-20, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.920353, Final residual = 0.0777223, No Iterations 1 bounding k, min: -2.2312e+102 max: 3.2152e+132 average: 1.51071e+129 ExecutionTime = 0.24 s ClockTime = 1 s Time = 17 smoothSolver: Solving for Ux, Initial residual = 2.68236e-13, Final residual = 4.81414e-14, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 5.77589e-13, Final residual = 8.05644e-14, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 2.57082e-14, Final residual = 2.85844e-15, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0256865, Final residual = 5.91851e-05, No Iterations 1 time step continuity errors : sum local = 3.03522e+100, global = -6.86672e+84, cumulative = -6.86672e+84 I've done some reaserch and tried as many fixes that have been suggested to others as I could, but nothing much has changed. Changing my fvSchemes managed to get it from 9 to 17 iterations, but that's still very little. At this point my best guess is that, since the pdf doesn't really specify the boundary condition values of k and epsilon, I must have chosen incorrectly, but I'm really not sure how to even begin working out what they should be. I've tried a few different ones, but none have led to anything. Here are what I think are the relevant files, let me know if any others would be helpful!: 0/U: Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet_one { type fixedValue; value uniform (0.1 0 0); } inlet_two { type fixedValue; value uniform (-0.2 0 0); } outlet { type zeroGradient; } walls { type fixedValue; value uniform (0 0 0); } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { inlet_one { type zeroGradient; } inlet_two { type zeroGradient; } outlet { type fixedValue; value uniform 0; } walls { type zeroGradient; } } Code:
dimensions [0 2 -3 0 0 0 0]; internalField uniform 14.855; boundaryField { inlet_one { type fixedValue; value uniform 14.855; } inlet_two { type fixedValue; value uniform 14.855; } outlet { type zeroGradient; } walls { type epsilonWallFunction; value uniform 14.855; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.375; boundaryField { inlet_one { type fixedValue; value uniform 0.375; } inlet_two { type fixedValue; value uniform 0.375; } outlet { type zeroGradient; } walls { type kqRWallFunction; value uniform 0.375; } } Code:
dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { inlet_one { type calculated; value uniform 0; } inlet_two { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } walls { type nutkWallFunction; value uniform 0; } } Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); turbulence bounded Gauss limitedLinear 1; div(phi,k) bounded Gauss linearUpwind grad(k); div(phi,epsilon) bounded Gauss linearUpwind grad(epsilon); div(phi,omega) $turbulence; div(nonlinearStress) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; } "(U|k|epsilon|omega|f|v2)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; minIter 1; } } SIMPLE { nNonOrthogonalCorrectors 0; consistent yes; residualControl { p 1e-2; U 1e-3; "(k|epsilon|omega|f|v2)" 1e-3; } } relaxationFactors { equations { U 0.95; // 0.9 is more stable but 0.95 more convergent ".*" 0.95; // 0.9 is more stable but 0.95 more convergent } } Thank you in advance for your help! Last edited by jrr75166; August 7, 2024 at 09:19. Reason: I copied 2 of the files from my case incorrectly. Edited to show the correct files. |
simplefoam convergence |
Understanding The Floating Point Exception Error Message | RussellHolt | OpenFOAM Running, Solving & CFD | 2 | August 6, 2022 01:00 |
ERORR floating point exception fluent udf | cudau.95 | Fluent UDF and Scheme Programming | 0 | August 4, 2021 23:11 |
Error: Floating Point Exception. How do I fix this? | Ryan T | FLUENT | 16 | July 30, 2020 19:52 |
Floating Point Exception - Mesh Related?? | edomalley1 | OpenFOAM Running, Solving & CFD | 2 | November 8, 2018 12:30 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 17:23 |
