Error Running buoyant Pimple Foam case
Old   August 5, 2024, 13:21
Exclamation Error Running buoyant Pimple Foam case
Matthew Donaldson
mrdonaldson1 is on a distinguished road
Hi, Im in intern at an engineering firm and I really need to get this to run and figured out how to fix it within a very short amount of time. The test im trying to run is simulating airflow through an open truck dock bay door in a cold storage facility where the inside is 36F and the outside is 75F. Ive used the motorBike simpleFoam tutorial to help build my mesh and that seems to be working and then I was trying to use the hotRoom BuoyantPimpleFoam tutorial to run the model but I cant get passed where it shows that no radiationModel and no Finite volume options. Ive tried looking it up and suspect that its an issue with FvSolutions or FvSchemes but I have never used openFoam before, except for running a few tutorials so i am completely out of my depth. I put a google drive link that shows all of the files and Ill upload a few photos. Any help or places to get help would be awesome. Im desparate at this point. https://drive.google.com/drive/folde...t_?usp=sharing
mrdonaldson1 is offline   Reply With Quote
Old   August 5, 2024, 13:50
Default FvSolutions
Matthew Donaldson
| \\ / O peration | Version: v2312 |
| \\ / A nd | Website: |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
"rho.*"
solver PCG;
preconditioner DIC;
tolerance 0;
relTol 0;
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-8;
relTol 0.01;
p_rghFinal
$p_rgh;
relTol 0;
"(U|h|e|k|epsilon|R)"
solver PBiCGStab;
preconditioner DILU;
tolerance 1e-6;
relTol 0.1;
"(U|h|e|k|epsilon|R)Final"
$U;
relTol 0;
SIMPLE
nNonOrthogonalCorrectors 0;
consistent yes;
potentialFlow
nNonOrthogonalCorrectors 10;
relaxationFactors
equations
U 0.9;
k 0.7;
omega 0.7;
cache
grad(U);
PIMPLE
//momentumPredictor yes;
//nOuterCorrectors 1;
nCorrectors 2;
pRefCell 0;
pRefValue 0; // p_rgh is typically referenced to 0
residualControl
p_rgh 1e-2;
Old   August 5, 2024, 13:51
Default FvSchemes
Matthew Donaldson
| \\ / A nd | Website: www.openfoam.com |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes //for transient sims, you need a time discretization scheme
default Euler; // First-order implicit time-stepping
gradSchemes //Gradient Scheme
default Gauss linear;
grad(U) cellLimited Gauss linear 1;
divSchemes // divergence scheme
default none;
div(phi,U) Gauss upwind;//linearUpwindV grad(U);
// Upwind for velocity, could use a higher-order scheme like linearUpwind
div(phi,h) Gauss linear;
div(phi,e) Gauss linear;
div(phi,K) Gauss linear;
div(phi,Ekp) Gauss linear;
turbulence Gauss upwind;
div(phi,k) $turbulence;
div(phi,epsilon) $turbulence;
div(phi,omega) $turbulence;
div(phi,T) $turbulence; // Upwind for Temperature
//div((nuEff*dev2(T(grad(U))))) Gauss linear; // for viscous terms
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss Linear;
laplacianSchemes //control the diffusion terms
default Gauss linear corrected;
/*laplacian((1|a(U)),p_rgh) Gauss linear corrected; //For pressure, considering velocity
laplacian(kappaEff,T) Gauss linear corrected; // For temperature Diffusion
laplacian(DT,alphat) Gauss linear corrected;*/
interpolationSchemes
default linear;
snGradSchemes //controls the gradient scheme normal to the surface
default corrected;
wallDist
method meshWave;
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
Buoyant Bouss Pimple Foam Documentation lfrigeri3 OpenFOAM 3 February 3, 2014 19:49
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
