chtMultiRegionFoam tank with band heater. No heat transfer. |
August 2, 2024, 16:49 |
Richard Overstreet
I'm working on a toy model of a simple tank with a band heater and don't see any heat transfer after meshing and running chtMultiRegionFoam in a 1 hour long simulation. The band heater should be providing 1000 watts of heat to the tank however, the temperature distribution on the tank/heater remains constant throughout the simulation. Right now I'm not sure what is wrong with the simulation configuration. The attached figure shows the simulation result at 3600 seconds. I am using OpenFoam version 2312.
Ultimately I would like to simulate water re-circulation from the inlet to the outlet in conjunction with heat transfer from the band heater. The full case is attached in a zip file. My work flow for meshing is: Code:
surfaceFeatureExtract blockMesh decomposePar -force mpirun -np 16 snappyHexMesh -parallel -overwrite reconstructParMesh -latestTime -constant splitMeshRegions -cellZones Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers false; geometry { tank.stl { type triSurfaceMesh; name tank; } }; castellatedMeshControls { maxLocalCells 1000; maxGlobalCells 100000; minRefinementCells 10; nCellsBetweenLevels 3; features ( { file "tank.eMesh"; level 5; } ); refinementSurfaces { tank { level (2 5); } } resolveFeatureAngle 30; refinementRegions { } locationsInMesh ( (( 50 75 130 ) water) (( 50 75 80 ) tank) (( 5 75 130 ) heater) ); allowFreeStandingZoneFaces false; } snapControls { nSmoothPatch 3; tolerance 1.0; nSolveIter 30; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap true; explicitFeatureSnap true; multiRegionFeatureSnap false; } addLayersControls { relativeSizes false; expansionRatio 0.0001; finalLayerThickness 0.0001; minThickness 0.0001; nGrow 0; featureAngle 10; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.0005; maxThicknessToMedialRatio 0.0003; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; } meshQualityControls { #include "meshQualityDict" nSmoothScale 4; errorReduction 0.75; } writeFlags ( scalarLevels layerSets layerFields ); mergeTolerance 1E-6; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; arch "LSB;label=32;scalar=64"; class polyBoundaryMesh; location "1/tank/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 3 ( tank { type mappedWall; inGroups 1(wall); nFaces 32450; startFace 444486; sampleMode nearestPatchFace; sampleRegion tank; samplePatch tank_to_water; } tank_to_water { type mappedWall; inGroups 1(wall); nFaces 38375; startFace 476936; sampleMode nearestPatchFace; sampleRegion tank; samplePatch tank; } tank_to_heater { type mappedWall; inGroups 1(wall); nFaces 6968; startFace 515311; sampleMode nearestPatchFace; sampleRegion heater; samplePatch heater_to_tank; } ) // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; arch "LSB;label=32;scalar=64"; class polyBoundaryMesh; location "1/heater/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 2 ( heater { type wall; inGroups 1(wall); nFaces 9886; startFace 102389; } heater_to_tank { type mappedWall; inGroups 1(wall); nFaces 6968; startFace 112275; sampleMode nearestPatchFace; sampleRegion tank; samplePatch tank_to_heater; } ) // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { tank_to_water { type compressible::turbulentTemperatureRadCoupledMixed; value $internalField; Tnbr T; kappaMethod solidThermo; qrNbr none; qr none; } tank_to_heater { type compressible::turbulentTemperatureRadCoupledMixed; value $internalField; Tnbr T; kappaMethod solidThermo; qrNbr none; qr none; } tank { type compressible::turbulentTemperatureRadCoupledMixed; value $internalField; Tnbr T; kappaMethod solidThermo; qrNbr none; qr none; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class volScalarField; location "0/heater"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 0 0 1 0 0 0 ]; internalField uniform 338; boundaryField { heater { type externalWallHeatFluxTemperature; mode power; Q uniform 1000; kappaMethod solidThermo; value $internalField; } heater_to_tank { type compressible::turbulentTemperatureRadCoupledMixed; qrNbr none; qr none; Tnbr T; kappaMethod solidThermo; useImplicit false; value $internalField; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { h { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.1; } hFinal { $h; tolerance 1e-06; relTol 0; } } PIMPLE { nNonOrthogonalCorrectors 0; } // ************************************************************************* // |
Coupled Heat and Mass Transfer | Mecroob | OpenFOAM Running, Solving & CFD | 1 | July 12, 2020 20:24 |
Radiation heat transfer with P1 and chtMultiRegionFoam | EliotSch | OpenFOAM Running, Solving & CFD | 2 | December 17, 2019 18:27 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
chtMultiRegionFoam: heat transfer coefficient between solids | brent | OpenFOAM Running, Solving & CFD | 0 | November 1, 2012 09:22 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
