Recording Static Pressure Higher than Total Pressure |
July 25, 2024, 00:26 |
Rep Power: 2 |
I知 running a shockwave based test in rhoCentralFoam where I知 experiencing pressure results that are higher than the total pressure calculated when using use tropic relations from the freestream Mach number. Starting at 32000 Pa at M=2.2, gives a total pressure of about 340kPa, but right after the first obstacle, the pressure rises to over 600 kPa. The inlet velocity is 580 m/s and the initial Temp is 152K. I知 using the freestream BCs along the inlet and zeroGradient for the outlets aside from the walls. I encounter similar results for more refined grids. These results are steady state within my simulation. Is there a known reason why this may be the case? Or could I be implementing my BCs wrong? Thank you. |
boundary condition, rhocentralfoam, total pressure increase |
Confision on total pressure and static pressure at far-field | Ryuzaki | Main CFD Forum | 2 | December 28, 2023 00:34 |
Total pressure obtained by postProcess utility is smaller than static pressure | Yanagi | OpenFOAM Post-Processing | 0 | August 12, 2022 08:44 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Static Pressure, Total Pressure | ufechner | FloEFD, FloWorks & FloTHERM | 5 | March 2, 2015 07:56 |
Boundary Conditions : Total Pressure or Velocity | Gearb0x | OpenFOAM Running, Solving & CFD | 2 | February 28, 2011 21:18 |
