DPMFoam/MPPICFoam not working correctly, particles behaving weirdly |
July 22, 2024, 05:32 |
Tommaso Pernatsch
Rep Power: 3 |
Hello everyone, I'm trying to simulate a vertical tube in OpenFOAM using the MPPICFoam solver. My fluid and my particles enter the tube on the upper (in the Z direction) face (inlet) and are supposed to flow downward, exiting in the bottom face (outlet). The boundary conditions for the particle-wall interaction is that theycan escape on the outlet while having a rebound bc with the external walls and the inlet. The problem is that, when I insert the particles (after the flow is fully developed) they instead try to go upwards, resulting in they being stuck on the inlet face. I tried basically everything but it doesn't seem to work. My Courant is always <0.8, the residuals are controlled and the simulation doesn't crash. Moreover, looking at the log file of the solver, it seems that the particles exiting my domain are one or two orders of magnitude higher than the ones entering the system:
Cloud: kinematicCloud injector: model1 Added 2 new parcels Cloud: kinematicCloud Current number of parcels = 1267 Current mass in system = 0.00031675 Linear momentum = (-2.04196e-09 9.61085e-09 0.000279082) |Linear momentum| = 0.000279082 Linear kinetic energy = 0.00150784 Average particle per parcel = 7.95239e+07 Injector model1: - parcels added = 1267 - mass introduced = 0.00031675 Surface film: - parcels absorbed = 0 - mass absorbed = 0 - parcels ejected = 0 Parcel fate: system (number, mass) - escape = 74488, 0.018622 Parcel fate: patch (walls|inlet) (number, mass) - escape = 0, 0 - stick = 0, 0 Parcel fate: patch outlet (number, mass) - escape = 0, 0 - stick = 0, 0 Min cell volume fraction = 0 Max cell volume fraction = 0.00141472 Min dense number of parcels = 2.82697 Does anyone have any ideas about what could be the problem? |
September 16, 2024, 11:09 |
Tommaso Pernatsch
Rep Power: 3 |
Hi everyone, I finally solved the problem.
The cause of the strange behaviour was the packingModel which you have to specify from the kinematicCloudProperties file. Setting it to none (I haven't tested with explicit) fixes the problem. |
lagrangian, mppicfoam, particle |
UDF for deleting particles in DPM | imanmirzaii | Fluent UDF and Scheme Programming | 12 | November 25, 2020 19:27 |
Particles are not hitting the wall | CedricVH | OpenFOAM Bugs | 23 | May 19, 2016 20:29 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
not sure my boundaires are working correctly | mbeals | FLUENT | 1 | May 13, 2009 16:28 |
particles tracks only working when initializing | djalil | FLUENT | 0 | November 24, 2008 06:12 |
