July 12, 2024, 12:10 |
simulation on a 3D badminton shuttlecock
Hi guys
I'm simulating a 3D shuttlecock with simplefoam solver together with k esilon model. However, when I simulated it with several angle of attack by editing the velocity components and changed the boundary condition to 2 inlets and 2 outlets, the below error messages came out. After that, I turned off the turbulence mode and it worked well. But is there anyone know how to get the results with turbulence model? #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/usr/lib/x86_64-linux-gnu/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PBiCGStab::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve() at ??:? #8 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) at ??:? #9 Foam::RASModels::kEpsilon<Foam::incompressibleMome ntumTransportModel>::correct() at ??:? #10 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/foamRun" #11 ? in "/usr/lib/x86_64-linux-gnu/libc.so.6" #12 __libc_start_main in "/usr/lib/x86_64-linux-gnu/libc.so.6" #13 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/foamRun" Floating point exception |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 09:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
