Issues adding k-omega turbulence to a solitary wave |
Jenny Cudmore
Rep Power: 0 ![]() |
I am trying to recreate a paper which simulated a wave tank with a solitary wave, with k-omega sst turbulence. I started with the OpenFOAM example waveMakerSolitary, changed it from 2D to 3D, and the wave looked reasonable, and not too different to the paper I am trying to recreate (see graph 1 in link below). However, when I turned on the k-w sst turbulence, the wave started moving really slowly (see graph 2 in link below). I'm assuming that I have made an error somewhere when turning the turbulence on, potentially when adding in the k, nut, omega files in 0.orig, or when editing the fvSchemes/fvSolution files, but I can't seem to work out how to fix it. I've tried changing the solvers, the discretization schemes, time schemes, mesh resolution etc but it still doesn't look right. I would be grateful if someone could work out where I'm going wrong. Thank you! ![]() You can access my code and graphs at: https://drive.google.com/drive/folde...usp=drive_link |
k-omega sst model, solitary wave, turbulence, wave flume, wavemakerflume |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 458 | July 10, 2024 02:57 |
Initial/boundary conditions for k and omega in k-omega-SST turbulence model | elmo555 | OpenFOAM Pre-Processing | 0 | January 24, 2018 10:31 |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
[waves2Foam] Turbulence problems, possibly due to density issues | app1e | OpenFOAM Community Contributions | 1 | December 6, 2015 15:20 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
