Charalampia Filippatou
Rep Power: 2 ![]() |
Hello guys! I'm currently trying to simulate the flow around the onera -m6 wing. the flow is compressible and I'm using the Spalart-Allmaras turbulence model. The grid I'm using is hybrid.
My main problem is that I'm bumping onto the same error which is the following: [2] #0 Foam::error: ![]() [2] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [2] #3 ? in "/lib/x86_64-linux-gnu/libm.so.6" [2] #4 Foam::hePsiThermo<Foam: ![]() ![]() ![]() [2] #5 virtual thunk to Foam::hePsiThermo<Foam: ![]() ![]() ![]() [2] #6 Foam::solvers::fluid::thermophysicalPredictor() at ??:? [2] #7 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/foamRun" [2] #8 ? in "/lib/x86_64-linux-gnu/libc.so.6" [2] #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [2] #10 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/foamRun" [optiplex:878600] *** Process received signal *** [optiplex:878600] Signal: Floating point exception (8) [optiplex:878600] Signal code: (-6) [optiplex:878600] Failing at address: 0x3e8000d6808 [optiplex:878600] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7bf852a42520] [optiplex:878600] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7bf852a969fc] [optiplex:878600] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7bf852a42476] [optiplex:878600] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7bf852a42520] [optiplex:878600] [ 4] /lib/x86_64-linux-gnu/libm.so.6(+0x1349c)[0x7bf85593a49c] [optiplex:878600] [ 5] /opt/openfoam11/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThe rmoINS_9psiThermo9compositeENS_11pureMixtureINS_19 sutherlandTransportINS_7species6thermoINS_12hConst ThermoINS_10perfectGasINS_6specieEEEEENS_22sensibl eInternalEnergyEEEEEEEE9calculateEv+0xe3d)[0x7bf843c36c3d] [optiplex:878600] [ 6] /opt/openfoam11/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZTv0_n72_N4Foam11 hePsiThermoINS_9psiThermo9compositeENS_11pureMixtu reINS_19sutherlandTransportINS_7species6thermoINS_ 12hConstThermoINS_10perfectGasINS_6specieEEEEENS_2 2sensibleInternalEnergyEEEEEEEE7correctEv+0x35)[0x7bf843c3aa85] [optiplex:878600] [ 7] /opt/openfoam11/platforms/linux64GccDPInt32Opt/lib/libfluid.so(_ZN4Foam7solvers5fluid23thermophysical PredictorEv+0x546)[0x7bf85009d686] [optiplex:878600] [ 8] foamRun(+0x3fb8)[0x64569d2d4fb8] [optiplex:878600] [ 9] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7bf852a29d90] [optiplex:878600] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7bf852a29e40] [optiplex:878600] [11] foamRun(+0x4765)[0x64569d2d5765] [optiplex:878600] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 2 with PID 0 on node optiplex exited on signal 8 (Floating point exception). I'm monitoring the residuals and even though they've reached a good order of accuracy for the complexity of the grid (10^-4 for pressure and 10^-5-6 for velocity). the solution hasn't converged. I'm also using rhoSimpleFoam solver. From the error that i get i understand that something occurs within the thermophysicalProperties File, however i don't understand what it is. I would be very grateful if someone has a tip to give me or an idea of what could be going wrong. |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 04:57 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
