buoyantPimpleFoam diverges with water
Old   July 5, 2024, 16:56
Default buoyantPimpleFoam diverges with water
Andy
Starcatcher is on a distinguished road
Hi folks,
for a while now I am trying make a buoyantPimpleFoam-simulation work. The physics are simple. Water domain of 200x250x100m. There is an inlet and an outlet inside.
The temperature of the domain is 280K the temperature of the water coming in 190K.
The simulation diverges with the notification that the maximum number if iterations is reached. I don't know what i do wrong. Please help.
Here my boundary conditions:
Outer walls are all "empty" for all Fields. I also tried zerogradient and the standard
Inlet and outlet are zones which i created based on stl files with "createBaffles -overwrite"
T for inlet is fixedValue for all other fields zeroGradient.
U for inlet is flowRateInletVelocity for inlet, pressureInletOutletVelocity for outlet and slip/noslip/or empty for the outer walls
for p and p_rgh i tried different stuff, however here i am not sure. I think the standard is fixedFluxPressure for everything except of outlet. at the outlet i also tried prghPressure for p_rgh and $calculated for p.
This simulation should not be so instable, no idea, why this solver makes so mus issues.
I also noticed that it is much more stable if i defeine the density as constant. But this misses the purpose of the simulation. I want to simulate buoyancy.
idealGas also works, but i need water.
Also the instability grows with the level of paralelisation.
If you need I can provide more information
Thank you for your help.
Starcatcher is offline   Reply With Quote
Old   July 8, 2024, 02:44
Default Problem solved
Andy
problem solved. among others the solution was to change the thermal energy equation setting from sensibleEnthalpy to sensibleInternalEnergy.
but why?
Modelling Saline water freezing for freeze water desalination Rhpeek FLUENT 0 May 3, 2021 15:55
InterFOAM water channel case diverges mkjmalik OpenFOAM Running, Solving & CFD 2 August 16, 2020 02:34
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 20:24
water velocity and water velocity in stationary frame of a water jet zehab CFX 0 May 11, 2020 04:17
How to model Salinity, density, fresh water & sea water grayback87 FLUENT 3 December 30, 2014 03:00
