Stopped at "Constructing face momentum equations" |
July 2, 2024, 23:28 |
Ching Liu
Rep Power: 9 |
I am using chtMultiRegionTwoPhaseEulerFoam to run a case. However, in the first step, it will stop without error. Below is where it stopped. It stopped at Constructing face momentum equations. Anyone know where the issue may come from? I checked the setup, but I did not find issues.
............. Selecting radiationModel none Adding fvOptions Courant Number max: 0.0021233211306 Region: solid Diffusion Number mean: 5.36113085225e-06 max: 0.000195580872819 deltaT = 1e-06 Courant Number max: 0.0021233211306 Region: solid Diffusion Number mean: 5.36113085225e-06 max: 0.000195580872819 deltaT = 1.20000480002e-06 Time = 1.2e-06 Solving for fluid region water MULES: Solving for alpha.gas MULES: Solving for alpha.gas MULES: Solving for alpha.gas alpha.gas volume fraction = 0 Min(alpha1) = 0 Max(alpha1) = 0 Constructing face momentum equations |
openfoam, stopped, without error |
[snappyHexMesh] Floating artifacts above and below mesh | chaos3 | OpenFOAM Meshing & Mesh Conversion | 12 | August 11, 2023 23:22 |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
