Rep Power: 0 ![]() |
I am running an open channel flow case in OpenFoam (using interfoam). It is a simple two-phase (water and air) flow over a bump (image below).
Given that the flow is subcrtical at the inlet and supercritical at the output I expect the height of the flow to decrease over the bump and remain the same thereafter. But I am getting different results. Is there a problem with these boundary conditions: Volume Fraction : zero gradient inlet and outlet. Velocity: Fixed value inlet and zero gradient outlet Pressure: zero gradient inlet and fixed value (p_rgh =0) pressure outlet. |
#interfoam, #openchannel, #openfoam |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
