Running Custom FiniteVolume Library replacing the out-of-the-box library on cluster |
Adwaith Nath
Rep Power: 5 ![]() |
I am trying to modify the MRF implementation in the finiteVolume library to incorporate the change in axis and origin with motion of a connected body. As the library is a base library, the method I used to use the modifications is to build the whole finiteVolume library in $FOAM_USER_LIBBIN and use the same name as the original finiteVolume library i.e. "libfiniteVolume.so". As OpenFOAM searches the $FOAM_USER_LIBBIN first before the $FOAM_LIBBIN, my custom finiteVolume library is loaded and used in place of the in-built library. Another way I did this is to put the library in the folder and add it to the start of $LD_LIBRARY_PATH. All the above methods work on my local computer. But when I try this on the cluster (supercomputer), it always loads the out-of-the-box / in-built version of finiteVolume. Could someone explain why this is happening and also probably suggest a better way to load and use my custom finiteVolume library in place of the in-built version on a cluster. Kind regards Adwaith Nath |
finitevolume, programming, super-computer |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
Junction Box Routine Shared Object Library | sam | CFX | 0 | March 3, 2008 12:52 |
Running FineTurbo on a Linux Cluster | Philipp Höfliger | Fidelity CFD | 3 | May 6, 2004 08:47 |
