MPPICInterFoam resets the speed values to zero |
Elvin
Rep Power: 2 ![]() |
Dear forum members, I have a problem with MPPICInterFoam. As far as I understand there is an interFoam under its hood.
I have a horizontal pipe in which I initialize the fluid. Let's say it occupies half of the volume. The fluid has an initial level and velocity (internal velocity, we're not talking about BCs) set with setFields. After running interFoam, no waves appear in this pipe, i.e. the liquid just flows. But when I run the same case in MPPICInterFoam (I do setFields here too), the fluid velocity that was set with setFields goes to zero on the first iterations and a wave appears. Solver parameters are the same both there and there. How can I solve this problem? Thanks in advance. |
interfoam, mppicinterfoam, openfoam, solver |
Flow across interface / Negative Moment Monitor Values | aptahaney | FLUENT | 3 | October 6, 2017 15:26 |
SIMPLE algorithm does not converge when using old pressure (correction) values | andreasp | Main CFD Forum | 3 | February 9, 2016 21:18 |
Ensight - node values -cell values | leo | FLUENT | 1 | May 12, 2010 08:47 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
node values or cell values? | aPpA | FLUENT | 0 | November 10, 2006 08:56 |
