Implementation of kEpsilon Lag Elliptic Blending Model |
Engineer
Rep Power: 13 ![]() |
I want to implement the new kEpsilonLagEB Turbulence model in OpenFOAM 2406. The source code is already availabe from "https://github.com/MAHTEP/EllipticBlending.git" . I had run the Allwmake command and a new library is already created. The tutorial provided works fine and when i want to implement for my case, the turbulence model is not found. I have also included the libray under system/controlDict file as mentioned in the tutorial file. Can anyone suggest what the correct procedure is. Thanks in advance Error: Selecting RAS turbulence model kEpsilonLagEB --> FOAM FATAL IO ERROR: (openfoam-2406) Unknown RAS model type kEpsilonLagEB Valid RAS model types : 14 ( EBRSM LRR LaunderSharmaKE RNGkEpsilon SSG SpalartAllmaras buoyantKEpsilon kEpsilon kEpsilonPhitF kOmega kOmegaSST kOmegaSSTLM kOmegaSSTSAS realizableKE ) file: constant/turbulenceProperties/RAS at line 20 to 24. From static Foam::autoPtr<Foam::RASModel<BasicTurbulenceModel> > Foam::RASModel<BasicTurbulenceModel>::New(const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&, const Foam::word&) [with BasicTurbulenceModel = Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foa m::CompressibleTurbulenceModel<Foam::fluidThermo> > >; Foam::RASModel<BasicTurbulenceModel>::alphaField = Foam::geometricOneField; Foam::RASModel<BasicTurbulenceModel>::rhoField = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>; Foam::RASModel<BasicTurbulenceModel>::transportMod el = Foam::fluidThermo] in file ../turbulenceModels/lnInclude/RASModel.C at line 158. |
Can I use RNG or Realizable kEpsilon as Low-Reynolds number turbulence model? | SimoY | OpenFOAM Running, Solving & CFD | 1 | January 24, 2024 11:40 |
BL k-ε-v2/k model implementation - OpenFOAM 4 | tomaszkura | OpenFOAM Programming & Development | 1 | April 27, 2018 03:20 |
Calculation time : SAS model vs kEpsilon model | MissCFD | CFX | 1 | February 2, 2018 01:03 |
Error in Implementation of Pressure-Strain Correlation in SSG Model?! | NablaDyn | OpenFOAM Programming & Development | 0 | October 6, 2017 11:03 |
Status of the implementation of the Transition Model Gamma-Re_th | imbamba | SU2 | 6 | April 29, 2016 13:56 |
