Non-Newtonian Rheology Model Units Inconsitency |
Mitch
Rep Power: 0 ![]() |
The computation of non-newtonian viscosity seems to be inconsistent in units. For example, the Herschel-Bulkley model is set up to provide a kinematic viscosity below the yield stress threshold, while calculating a dynamic viscosity above the yield stress threshold: nu = min ( nu0, (tau0 + k*gamma_dot^n)/(gamma_dot)) The output is specified as kinematic viscosity units, so clearly the equation is not correct if tau0 units are N/m^2 and gamma_dot units are s^-1. https://www.openfoam.com/documentati...8C_source.html The documentation I can find online seems to ignore this inconsistency when describing input parameters: https://doc.cfd.direct/openfoam/user...sport-rheology Unless I'm missing something, the solution should be providing the tau0 and k parameters already divided by density. If true, this is straight forward but lacking/unclear in the documentation. I am hoping to confirm this with the community before I implement. Cheers |
Marcin
Rep Power: 13 ![]() |
There is the inconsistency in units for non-Newtonian viscosity calculations in the Herschel-Bulkley model. The inconsistency arises because the model expresses shear stress (tau) in units of N/m^2 (Pascals), while the shear rate (gamma_dot) is in units of s^-1 (reciprocal seconds).
More at https://howtooansys.blogspot.com/202...es-in-non.html
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
inconsistencies, rheology, units |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Looking for a commerical software to model screen printing (rheology) | Donghun Lee | Siemens | 0 | May 30, 2000 17:12 |
