Christoph Trier
Rep Power: 2 ![]() |
Hey guys,
In my Simulation, I am observing backflow back into the domain. I've attempted to resolve this using the inletOutlet boundary condition, which should prevent backflow. However, the backflow issue persists, and I'm puzzled as to why this is happening. My outlet condition. Image of the backflow and my Domain. Code:
outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); I also tried the pressureInletOutletVelocity with total pressure for the p_rgh. Can someone help me out here? I am using the Boussinesq equation of state and the buoyantPimpleMhdFoam solver, which is just a combination of the buoyantPimpleFoam and the Mhd one. I use Openfoam v2312 I have a GitHub link to my case if anyone wants to check it. https://github.com/Lorddrinkalot/Ope..._shape/L_shape Last edited by Lorddrinkalot; June 24, 2024 at 09:02. Reason: Better Image |
Marcin
Rep Power: 13 ![]() |
Backflow in OpenFOAM simulations can arise from various factors, even when using the inletOutlet boundary condition. Here are some potential causes and solutions for your specific scenario:
Inconsistent Pressure Field: Double-check that the pressure field within the domain behaves as expected. Unrealistic pressure gradients can induce backflow. You can visualize the pressure field to identify any anomalies. * Insufficient Outlet Length: Extending the outlet further downstream can sometimes mitigate backflow, especially if the flow hasn't fully developed. This allows for a more natural pressure recovery. * Incorrect Boundary Conditions More at link below https://howtooansys.blogspot.com/202...ckflow-in.html
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
Christoph Trier
Thanks for your answer.
I actually dislike some behaviour in the p_rgh field. (Image included.) It has a very strong gradient, but I thought that's the result of the backflow. Mh ok. I will try to stabilise my simulation. Last edited by Lorddrinkalot; June 25, 2024 at 05:48. Reason: Image |
Christoph Trier
Hey, I have changed my boundary conditions, and it appears to work. I don't see any backflow.
However, when I want to change my timestep, backflow again occurs. How? One simulation with a fixed timestep has no backflow. When changing to an adjustable time step, the backflow is there again. |
backflow |
Tackling Backflow using extended domain | soumitra2102 | Main CFD Forum | 10 | September 11, 2019 15:52 |
Inducing backflow restrictions in domain interface for multiphase flow | DarrenC | CFX | 4 | August 6, 2014 21:17 |
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) | Josh | CFX | 9 | August 18, 2009 11:31 |
Problem with integrals and averages if backflow?? | Amit | FLUENT | 0 | October 19, 2006 18:54 |
Swirl in backflow on pressure outlets | Jonas Larsson | FLUENT | 17 | February 3, 2000 02:14 |
