Matt
Rep Power: 2 ![]() |
Ok, i have no idea why openfoam is causing a fatal error.
Nothing has changed with my test setup except the fact that i set the flow from: steady, single phase, isothermal, viscous, RANS To: steady, single phase, high mach number, viscous, RANS All other properties stayed the same.. air at stp and now it gives me this error: Thanks for any help 23:09:02 mpiexec.exe : [2] At line:4 char:5 + & mpiexec -np $NumProcs $cmd -parallel $args 2>&1 | tee log.$sol + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : NotSpecified: ([2] :String) [], RemoteException + FullyQualifiedErrorId : NativeCommandError 23:09:02 [0] [3] [1] [2] [0] [3] [1] 23:09:02 [2] [0] [3] [1] --> FOAM FATAL ERROR: --> FOAM FATAL ERROR: --> FOAM FATAL ERROR: --> FOAM FATAL ERROR: (openfoam- (openfoam- (openfoam- (openfoam- 2212 2212 2212 2212 ) ) ) ) [2] [0] [3] [1] failed lookup of thermophysicalProperties (objectRegistry region0) available objects of type fluidThermo: 0() failed lookup of thermophysicalProperties (objectRegistry region0) available objects of type fluidThermo: 0() failed lookup of thermophysicalProperties (objectRegistry region0) available objects of type fluidThermo: 0() failed lookup of thermophysicalProperties (objectRegistry region0) available objects of type fluidThermo: 0() [2] [0] [3] [1] [2] [0] [3] [1] [2] [0] [3] [1] From From 23:09:02 From From const Type& Foam: ![]() const Type& Foam: ![]() const Type& Foam: ![]() const Type& Foam: ![]() [2] [0] [3] [1] in file in file in file in file /root/OpenFOAM/OpenFOAM-v2212/src/OpenFOAM/lnInclude/objectRegistryTemplates.C /root/OpenFOAM/OpenFOAM-v2212/src/OpenFOAM/lnInclude/objectRegistryTemplates.C /root/OpenFOAM/OpenFOAM-v2212/src/OpenFOAM/lnInclude/objectRegistryTemplates.C /root/OpenFOAM/OpenFOAM-v2212/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line at line at line at line 571 571 571 571 . . . . [2] [0] [3] [1] FOAM parallel run exiting FOAM parallel run exiting FOAM parallel run exiting FOAM parallel run exiting [2] [0] [3] [1] 23:09:02 |
Matt
any ideas as of yet?
thanks |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
