FOAM FATAL IO ERROR: attempt to read beyond EOF |
Yinghao Zhou
Rep Power: 2 ![]() |
I tried to set laplacianSchemes to Gauss linear quadraticFit to get higher accuracy, but the following error was reported:
FOAM FATAL IO ERROR: -->attempt to read beyond EOF file: /home/guest/OpenFOAM/OpenFOAM-6/tutorials/SOFC/zyh/FGM_porosity/0.02Vtest/system/Ni/fvSchemes.laplacianSchemes.default at line 47. From function virtual Foam::Istream& Foam::ITstream::read(Foam::token&) in file db/IOstreams/Tstreams/ITstream.C at line 82. FOAM exiting Code:
laplacianSchemes { default Gauss linear quadraticFit; } interpolationSchemes { default quadraticFit; } snGradSchemes { default uncorrected; } |
talop
Rep Power: 3 ![]() |
The error means that the laplacianSchemes sub-dictionary does not accept "Gauss linear quadraticFit" as a valid scheme. Try writing a random word (e.g. type banana ![]() Best |
Yinghao Zhou
[Salome] Salome import "Cannot find file "points" in directory..." | mismichael | OpenFOAM Meshing & Mesh Conversion | 6 | June 24, 2024 03:17 |
FOAM FATAL IO ERROR attempt to read beyond EOF | unoder | OpenFOAM Running, Solving & CFD | 10 | April 16, 2024 03:03 |
FOAM FATAL IO ERROR: attempt to read beyond EOF | HeloïseM | OpenFOAM | 1 | February 26, 2023 10:14 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
