Fantastic Boy
Rep Power: 8 ![]() |
Hi all,
I am using MPPIC Foam to simulate the particles in a ventilation room. I am wondering before the particles are injected into the room, e.g. SOI=2001s, will the flows reach a steady state? If it is, will it be similar to the results obtained using a steady-state solver like icoFoam? Thank you. Kind regards, Lam WK |
mppic, particle, steady-state |
UDF for particle injection using file | shahjehan | Fluent UDF and Scheme Programming | 2 | June 28, 2020 10:44 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 07:53 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 22:50 |
