Sebastian Thaler
Rep Power: 2 ![]() |
Hey,
i am relatively new to OpenFoam, but i successfully did some cases with the incompressibleFlow SolverModule and incompressible flows with the fluid SolverModule. I am working with OF11, so the .org-version. Now i am trying to run a laminar compressible flow in a easy straight-pipe geometry with the perfectGas-model, but i just cant get a case running. I searched through the tutorials and also the template-files for a CHT case, but i do not get, what to do ![]() So now my questions: and i guess they connected ![]() - there are several discritisation schemes that i found: div(phi(p|rho) div(phid,p) div((phi|interpolate(rho)),p) Which one of these do i need and whats the difference (i read smth. about Ma-number) between them. - when do i use a solver for p and when for p_rgh? and for what do i have to whatch out for when i set their initial values? - I add the most important files from my template case with rhoConst. What do i have to change? Help would be much appreciated. Or maybe just some hint where to find the information. I searched the web, the user guide, several tutorials but i am completly stuck ![]() Here the files, because upload make troubles: 0/p_rgh Code:
dimensions [ 1 -1 -2 0 0 0 0 ]; internalField uniform 0; boundaryField { inlet { type fixedFluxPressure; } outlet { type fixedValue; value uniform 0; } wand { type fixedFluxPressure; } } Code:
dimensions [ 1 -1 -2 0 0 0 0 ]; internalField uniform 1e05; boundaryField { ".*" { type calculated; value uniform 0; } } Code:
// AIR @ T = 293 K = 20 °C thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } mixture { specie { nMoles 1; molWeight 28.9; // [g/mol] } thermodynamics { Cp 1006; // [J/kg*K] Hf 0; } transport { mu 1.81e-05; // [Pa*s] Pr 0.71; } } Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,e) Gauss linearUpwind grad(U); div(phi,U) Gauss linearUpwind grad(U); div(phi,(p|rho)) Gauss linear; div(phi,K) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } Code:
solvers { U { solver PBiCGStab; preconditioner DILU; tolerance 1e-6; relTol 0.1; } e { solver PBiCGStab; preconditioner DILU; tolerance 1e-6; relTol 0.1; } p_rgh { solver GAMG; smoother GaussSeidel; tolerance 1e-7; relTol 0.01; //minIter 3; maxIter 100; } } PIMPLE { momentumPredictor yes; nCorrectors 1; nNonOrthogonalCorrectors 1; } relaxationFactors { fields { p_rgh 0.3; } equations { U 0.7; ".*" 0.7; } } |
Simulation just stops output writing, but keeps running | blaise | OpenFOAM Running, Solving & CFD | 6 | March 27, 2024 04:49 |
equationOfState icoTabulated error | carl_r | OpenFOAM Running, Solving & CFD | 3 | March 14, 2022 06:05 |
Difference between psiThermo and rhoThermo. | wenxu | OpenFOAM Running, Solving & CFD | 19 | September 14, 2021 10:17 |
WLF from OF7 | Pisolino85 | OpenFOAM | 2 | April 26, 2020 06:34 |
Error problem while running sadia d lts tutorial | kane | OpenFOAM Running, Solving & CFD | 2 | May 26, 2018 03:38 |
