fields writing on demand?
Old   June 13, 2024, 04:32
Default fields writing on demand?
geth03 is on a distinguished road
hi all,
i run particlefoam in of10. one can turn off coupling and solve for lagrangian particles only without changing flow field. the bad thing is that for every lagrangian output in a certain time step the solver automatically writes out every field i have (U,p,turbulence fields). it takes up so much memory for a field that does not even change.
i searched up everything but could not find if one can stop that memory expensive field outputs.
any help is appreciated.
geth03 is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 09:27
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
