Trayana Georgieva
Rep Power: 2 ![]() |
Greetings, everyone!
Working on a bachelor thesis, without any previous CFD modelling experience, my colleagues and I wanted to do some analysis for a propeller, since we are designing a quadcopter. We took data from APC propeller (7"x3"), and modelled it in CATIA, after which we used Xflr for generating polars. We followed Capitao's report (https://www.tfd.chalmers.se/~hani/ku...itaoReport.pdf) closely, to try to get an estimate of the forces, and added extra calculations based on the first citation - Development of Virtual Blade Model for Modelling Helicopter Rotor Downwash in OpenFOAM. We scaled the disk to match our dimensions, and inputted our profiles and section divisions. However, despite that, we get underestimated values. Modelling the case for 10,000 RPM, in hover, we obtain the following final results: rotorDisk output: min/max(AOA) = 2.7406107, 12.881586 min/max(eps) = 2.1925445, 13.558032 Rotor thrust = 1.8003661 Rotor torque = 0.023655741 Rotor power = 24.772234 Effective drag = -0.41199112 Effective lift = 1.8003661 smoothSolver: Solving for Ux, Initial residual = 9.7307958e-05, Final residual = 9.715026e-06, No Iterations 6 smoothSolver: Solving for Uy, Initial residual = 9.6761527e-05, Final residual = 9.65839e-06, No Iterations 6 smoothSolver: Solving for Uz, Initial residual = 2.6749538e-05, Final residual = 2.3465639e-06, No Iterations 8 GAMG: Solving for p, Initial residual = 6.2058751e-05, Final residual = 4.4921504e-06, No Iterations 2 time step continuity errors : sum local = 3.2287854e-06, global = 3.2293843e-07, cumulative = 0.0036784382 smoothSolver: Solving for omega, Initial residual = 2.762776e-05, Final residual = 2.722353e-06, No Iterations 10 smoothSolver: Solving for k, Initial residual = 3.0377333e-05, Final residual = 2.4706647e-06, No Iterations 11 ExecutionTime = 148.88 s ClockTime = 153 s SIMPLE solution converged in*277*iterations Nonetheless, the file provided by APC Propellers indicates the following values: Thrust - 2.815N, Power 30.58W, Torque 0.029 Nm. Close to ours, but not enough, we were wondering if there is something that we could be missing. Our current belief is that the polars are off, but unsure how to check those. Lack of experience perhaps prevents us from using the right boundary conditions, too... I'll send our current progress, and if anyone takes the time to provide some insight, we'll greatly appreciate it! |
actuation disk, power, propeller, rotordisk, thrust |
Wrong values calculating Cd and Cl | guillenmugerza | FLUENT | 3 | March 16, 2020 12:21 |
How can values of profile(k, epsilon) not change? | minque | FLUENT | 4 | January 22, 2020 14:14 |
Hovering rotor thrust coeff values | Kinng | STAR-CCM+ | 3 | November 14, 2019 11:05 |
Numerical errors in nested domain with pre-calculated boundary values | Arnoldinho | OpenFOAM Running, Solving & CFD | 3 | April 4, 2012 10:31 |
Ensight - node values -cell values | leo | FLUENT | 1 | May 12, 2010 08:47 |
