Pressure fluctuations problem with dynamic mesh |
June 5, 2024, 12:22 |
Renato
Rep Power: 3 |
Dear Foamers,
I have an issue with a simulation that uses dynamicMesh (sliding mesh). My pressure is subject to significant fluctuations between timesteps that are almost certainly not physical. This behavior is most likely due to the dynamic mesh and something I might be setting up incorrectly because when I simulate the same case with MRF instead of dynamicMesh, these fluctuations disappear. Here are some details: -The case is quite simple: a cross with 4 arms rotating on its axis enclosed in a stationary cylinder. The walls of the cross have movingWallVelocity, while those of the cylinder have noSlip. -The simulation is performed with PIMPLE, k-omegaSST with y+ = 8 (average), and 15 layers. -The dynamic motion solver used is solidBody omega 400 rad/sec, with cyclicAMI interfaces: noOrdering, matchTolerance 1e-5. -I am using 5 outer correctors, 3 correctors, and 1 nonOrthogonalCorrector, the non-orthogonality is <65 and the skewness is <3.5. -I am using a fixed timestep of 1e-5, which ensures a Courant number of about 1.5. -Second-order in space with gradient limiter and backward in time. My main concern is that the PIMPLE loops never reach convergence, and this might be the problem. I tried setting them to a very high value (30), but the solver executed all 30 and took forever for one iteration... Do you have any idea what the problem might be and what I can try? |
September 24, 2024, 09:20 |
I had the exact same problem as you, did you solve it please?
dynamicmesh, pimplefoam, pressure fluctuations |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Generate convective pressure fluctuation | Bananenflanke | CFX | 10 | May 12, 2021 18:33 |
Dynamic mesh setting problem | Youwu | FLUENT | 7 | June 1, 2020 05:47 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
zeroGradient pressure and moving mesh | kassiotis | OpenFOAM Running, Solving & CFD | 0 | July 22, 2009 09:28 |
