simpleFoam convergence issue on turbulent sim (yPlus) |
June 2, 2024, 14:57 |
Santi Parera
Rep Power: 7 |
Hey there,
I want to simulate a Venturi pipe with a geometry a little bit complex. Fluid is water and Reynolds is fully turbulent. For now I'm working on a simplified geometry that consists just in two pipes forming a T. This is my workflow: 1. Solve for 1000 cPs (laminar) - linearUpwind, converges perfectly 2. Solve for 100 cPs (laminar) using previous data - linearUpwind, converges perfectly 3. Solve for 10 cPs (turbulent) using previous data - upwind, converges perfectly 4. Solve for 10 cPs (turbulent) using previous data - linearUpwind, does not converge 5. Solve for 1 cPs (turbulent) using previous data - upwind 6. Solve for 1 cPs (turbulent) using previous data - linearUpwind As you can see, I cannot overpass point 4 because it does not converge... Mesh is done by blockMesh and snappyHexMesh and checkMesh with all checks points just 1 failed check that is "concaveCells". Nonorthogonality is max 61, av 9. I'm using simpleFoam with kOmega SST model and 2 nonorthogonal correctors. I think it is a problem related with yPlus because I have been refining carefully the surface zones and this has allowed me to decrease the viscosity but now I have a max yPlus of 2,6 with wallFunctions and I can't improve the results for the point above said. Of course I can send all sim files anyone need. Thanks in advance. |
simplefoam, turbulence, yplus |
No Convergence for High Viscosity (simpleFoam, Steady-State) | S03r3n | OpenFOAM Running, Solving & CFD | 3 | June 11, 2024 05:24 |
simpleFoam convergence issue | dnsuman | OpenFOAM Running, Solving & CFD | 12 | November 28, 2019 16:39 |
Convergence issue with moving surface | pd.iiest | FLUENT | 0 | August 30, 2019 03:06 |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 06:27 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
