Channel flow with uniform inflow using LES-WALE |
May 31, 2024, 12:39 |
Huawei
Dear formers,
I’m a beginer. I want to simulate a channel flow with an uniform inflow of 25.5m/s using LES method and WALE model. The version of openfoam is openfoam11. The solver is rhoPimpleFoam. The boundary condition and initial condition are as flows: BI.png I’m so confused that the final velocity/Pressure/Temperature/nut/alphat field(at time of 0.001s) is nonuniform: Field.jpg The U/P/T/nut/alphat are setted as follows: UPTnut.jpgalphat.png momentumTransport and physicalProperties: fvSolution and fvSchemes: MP.jpg I so confused ,please help ,thanks! |
channel flow, les-wale |
wallHeatFlux utility for an incompressible case | Mr.Jingles | OpenFOAM Post-Processing | 67 | April 6, 2023 03:25 |
FOAM FATAL ERROR: Maximum number of iterations exceeded: 100 | antoniomollo | OpenFOAM Running, Solving & CFD | 5 | March 2, 2023 06:13 |
Film cooling problem | arun1994 | OpenFOAM | 0 | October 26, 2020 09:08 |
simpleFoam Floating point error (Core Dumped) | sam.ho | OpenFOAM Running, Solving & CFD | 2 | December 31, 2013 06:57 |
Serious problems to perform LES of the channel flow | LB76 | OpenFOAM Verification & Validation | 5 | June 21, 2012 07:40 |
