Request for Validation Cases: Airfoil Simulation with k-ω SST Turbulence Model |
May 30, 2024, 06:04 |
Alex
Rep Power: 2 |
Hi everyone,
I am currently working on simulating airfoil performance using OpenFOAM and would greatly appreciate some assistance with validation cases. Specifically, I am interested in simple foam calculations of an airfoil using the k-ω SST turbulence model. My goal is to compare my results with real-world values to ensure the accuracy of my simulations. Requirements:
Desired Output:
Boundary conditions Solver settings Turbulence model parameters Purpose: I plan to use these cases to validate my own simulation setup in OpenFOAM. Having access to detailed validation cases will help me check my simulations against known results and refine my computational models accordingly. Additional Information: If possible, please provide any relevant OpenFOAM case files or scripts that you used for your simulations. This will allow me to reproduce the results more effectively and understand the nuances of your setup. Thank you in advance for your help. I look forward to your responses and any suggestions or guidance you can provide. Best regards, Snacker |
airfoil |
[GUIDE] Switching turbulence model to SpalartAllmaras | gabrielfelix | OpenFOAM Running, Solving & CFD | 1 | March 24, 2022 20:19 |
Identifying location of turbulence model shift in DES or SST models | Jonassvantesson | Main CFD Forum | 2 | October 9, 2020 11:52 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
Which turbulence model is applicable for Plain diffuser flow simulation in openFOAM? | mukut | OpenFOAM Running, Solving & CFD | 4 | January 30, 2015 08:06 |
