rhoSimpleFoam divergence error on trans and super sonic Mach numbers |
May 30, 2024, 02:22 |
Vadim Mikhailov
Rep Power: 2 |
Hello everyone!
Im trying to solve simple bullet external aerodynamics problem. I use freestreamVelocity and freestreamPressure boundary conditions and kOmegaSST turbulence model with SIMPLE (consistent yes option included) pressure-velocity coupling. My setup is very similar to aerofoilNACA0012 tutorial (im using OpenFOAM Foundation version). The problem is: on Mach 0.4 and 0.6 solver runs fine and converges sucsessfuly, but on Mach number 0.95 and higher it diverges. The quesion is: is it possible to model transonic and supersonic flows (Mach 3) with rhoSimpleFoam or I should use something like rhoCentralFoam or hisa solver? Maybe I need some special settings for my case to stabilize solution? I can upload some files of my case if needed |
May 30, 2024, 03:25 |
Rep Power: 9 |
I'm not sure if this will solve your problem, but have you activated the "transonic" switch? https://doc.openfoam.com/2312/tools/.../compressible/
