Defining power distribution to a region
Old   May 29, 2024, 15:26
Post Defining power distribution to a region
george
scfd is on a distinguished road
Below, there is a power distribution that varies only with height for a solid channel.
1)Since we are defining enthalpy, is the energy generation for each cell defined in Joules or Joules per kilogram? If it is in Joules per kilogram, does it require any changes in fvOptions?
2)Why is source[i] -= Equation used in the syntax instead of source[i] = Equation even though there is no increase or decrease over time? Also, when I change it to source[i] += Equation, no power generation occurs.
3)Despite having a constant defined power value for each cell in the first iteration, why do the expected temperatures occur after a certain iteration? Could it be due to the initial conditions?
powerDist
    type          scalarCodedSource;
    name          PS;
    scalarCodedSourceCoeffs
		selectionMode   cellZone;
		cellZone        solidRegion;
		fields          (h);
        codeInclude
        codeCorrect
	codeAddSupRho
			const scalarField& zAx = mesh_.C().component(2);
			//const scalarField& cellVolumes = mesh_.V();
			scalarField& source = eqn.source();
			forAll(zAx, i)
				scalar zValue = zAx[i];
				//scalar cellVolume = cellVolumes[i];
				scalar eqq = sin(zValue); // long polynomial source equation
				source[i] -= eqq;
	codeConstrain
regards
scfd
scfd is offline   Reply With Quote
fvoptions, power, source
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Defining the region between two layers of fluid in a reacting flow bamidoao FLUENT 0 February 15, 2017 22:49
Taking too much for run Grimoli OpenFOAM Running, Solving & CFD 5 November 26, 2013 21:07
Variable distribution over a Region LittleBart CFX 1 August 7, 2011 19:52
Defining wall boundary region saleem Siemens 3 August 31, 2005 04:58
