High Cd Coefficients in Airfoil Validation Simulation |
May 29, 2024, 08:41 |
Alex
Rep Power: 2 |
Hello together,
I'm facing an issue with my airfoil validation where I'm getting significantly higher Cd (drag coefficient) values than expected. Interestingly, the Cl (lift coefficient) values are nearly spot on. Here's what I'm using for my simulations:
Despite these settings, my Cd values are almost double the expected values obtained from wind tunnel experiments. If you need any more information or have suggestions on what might be causing this discrepancy, please let me know. Thanks in advance for your help! Best regards, Snacker |
May 29, 2024, 14:45 |
Alex
Rep Power: 2 |
Here is a link to the .tar files for Low and High Re calculations.
Files were to big for uploading it here. https://drive.google.com/drive/folde...r8?usp=sharing |
airfoil, drag coeffcients |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
3D Airfoil simulation cd to low kklOmega-Modell | turbine123 | OpenFOAM Running, Solving & CFD | 2 | May 19, 2021 16:39 |
Airfoil Simulation for Validation Purposes | Angela Bong | Main CFD Forum | 7 | September 13, 2006 13:04 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
