blockMesh with error "Attempt to return dictionary entry as a primitive" |
May 29, 2024, 01:35 |
Yidonguk
I ran blockMesh and got the error message below:
--> FOAM FATAL IO ERROR: Attempt to return dictionary entry as a primitive file: /home/dnrmehd/OpenFOAM/dnrmehd-11/run/test1/system/blockMeshDict/boundary from line 53 to line 76. From function virtual Foam::ITstream& Foam::dictionaryEntry::stream() const in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 83. and blockMesh file is Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 11 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; vertices ( (0 0 0) // 0 (10 0 0) // 1 (10 10 0) // 2 (0 10 0) // 3 (0 0 12) // 4 (10 0 12) // 5 (10 10 12) // 6 (0 10 12) // 7 ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 24) simpleGrading (1 1 1) ); edges ( arc 0 1 (5 5 0) arc 1 2 (10 5 5) arc 2 3 (5 15 0) arc 3 0 (-5 5 0) arc 4 5 (5 5 12) arc 5 6 (15 5 12) arc 6 7 (5 15 12) arc 7 4 (-5 5 12) ); boundary { walls { type wall; faces ( (0 3 7 4) (1 2 6 5) (0 1 5 4) (2 3 7 6) ); } bottom { type wall; faces ( (0 3 2 1) ); } top { type wall; faces ( (4 5 6 7) ); } } mergePatchPairs ( ); // ************************************************************************* // what should i do |
blockmeshdict, error |
buoyantSimpleRadiationFoam - "Attempt to return primitive entry [...] mixture [...]" | javad814 | OpenFOAM | 6 | June 14, 2022 00:57 |
Add Temperature to multiphaseInterFoam | nthiers | OpenFOAM Programming & Development | 6 | February 17, 2016 08:42 |
Creating a new field from terms of the turbulence model | HaZe | OpenFOAM Programming & Development | 15 | November 24, 2014 13:51 |
Derive fixed number of phase from clone () in multiphaseEulerFoam Solver | Aj Nair | OpenFOAM Programming & Development | 0 | December 16, 2013 20:41 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
