Rep Power: 0 ![]() |
I'm running a CFD simulation for an urban area using the simpleFoam solver and the standard k-epsilon turbulence model.
To check the simulation settings, I ran the simulation with an empty domain to verify the Horizontal Homogeneity of the Atmospheric Boundary Layer (HHABL). After the simulation was completed, I used ParaView to check the results. I found that the inlet profiles differed from the downstream/incident wind profiles. Additionally, the velocity I had inputted for the ABL setting (Uref at Href = 15 m) is different from the simulation results. Please see the attached figure. There is flow in the upstream region that affects the wind profile downstream and the wind velocity at specific heights. Is there any solution to this? Should I use a different solver type, or is there something I have missed? |
Hey, yonggi_ did you find some results I am having some problems.
#abl, #simple algorithm, #solver, #windprofile |
Fluent phase change in a horizontal tube | eliastorca | FLUENT | 3 | January 26, 2024 21:49 |
Rotated Airfoil with horizontal Velocity Vs. Horizontal Airfoil with inclined veloci | KarimSayed | FLUENT | 5 | November 11, 2020 03:24 |
Is it possible to model natural convection in a 2D horizontal model in fluent | caitoc | FLUENT | 1 | May 5, 2014 13:32 |
Vector arrow point vertical and horizontal mean? | warlocklw | ANSYS | 0 | May 24, 2012 02:53 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
