interFoam Open Channel Flow interFoam: high velocities & small time steps
Old   May 27, 2024, 12:58
Default interFoam Open Channel Flow interFoam: high velocities & small time steps
Charly23 is on a distinguished road
Hi everybody,
I am trying to simulate open channel flow using InterFoam solver and k-omegaSST for turbulence modelling. What I know is the flowRate at the inlet and the water level at the outlet. I have tried all kinds of different BC but I always get problems with high velocities in the air and water phase, which lead to a very small time step (picture2). When I used static pressure as outlet condition for the water phase: air flows into the water domain (picture1). That is why I choose the velocity condition for the outlet of the water and the air outlet is included in the open BC. In general, I am interested in the velocity ditribution of the water surface. My channel is relatively shallow, but I still want to do it in 3D. (length 19m and water depth 0.2m)
I therefore assume a problem with my initial or boundary conditions or with my mesh:
Initial condition: constant water level at 0.2 m, zero velocity (0 0 0) everywhere
Inlet BC:
1. U: fixedNormalInletOutletVelocity
2. p_rgh: fixedFluxPressure
3. alpha_water: inletOutlet
Inlet_Air BC:
1. U: pressureInletOutletVelocity
2. p_rgh: zeroGradient
Outlet BC:
3. alpha.water: inletOutlet
Open (Including the air phase outlet):
2. p_rgh: totalPressure
Channel bottom & side walls:
1. U: movingWallVelocity
3. alpha.water: zeroGradient
I'm happy to provide you with more information (i.e. BC for k, epsilon and nut) and would be really grateful if I could get some advice on how to solve this problem. Thanks in advance!
Charly23 is offline   Reply With Quote
Old   May 28, 2024, 05:22
Sorry, here is the other picture I was talking about.
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 13:16
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
