Issues with Phase-Focused Waves in waveFoamGABC Example in waves2Foam |
May 27, 2024, 01:40 |
Hello everyone,
I am currently working with the waveFoamGABC solver in the waves2Foam library, specifically focusing on the phase-focused wave example. I have encountered a few issues and would appreciate any insights or suggestions from the community. Problem Description: I am trying to generate phase-focused waves with a predetermined focusing height of 0.07m and a focusing time of 32 seconds. However, I have noticed that the actual focusing time is earlier than expected, and the wave height at the focus point is lower than anticipated.When running the original example, I noticed that waves are generated from both ends of the numerical tank towards the center before they start generating from the inlet. Thank you very much for your help and suggestions! Best regards, Lyu. |
phase-focused waves, wavefoamgabc, waves2foam |
[waves2Foam] Modifying waves2Foam to simulate focused waves | Metqeu | OpenFOAM Community Contributions | 4 | May 28, 2024 12:22 |
Focused Waves | Haider15 | OpenFOAM Programming & Development | 0 | September 6, 2023 01:15 |
Focused Waves | Haider15 | OpenFOAM Running, Solving & CFD | 0 | September 6, 2023 01:12 |
Multidirectional focused waves | YNLSW911219 | REEF3D | 9 | May 4, 2022 05:09 |
[waves2Foam] Is it possible to specify as an input to OceanWave3D a focused waves? | katakgoreng | OpenFOAM Community Contributions | 2 | December 3, 2015 13:11 |
