The velocity calculated using simpleFoam exhibits non-physical rise |
May 26, 2024, 02:55 |
Yanjun Tong
Rep Power: 6 |
I currently calculating case of wind around buildings and encoutered weired velocity rise. The geometry is as follows, the flow direction is from north to south, with the value of (1 0 0). The mesh contain some grid with high non-orthogonal
Checking geometry... 78 Overall domain bounding box (-621.9 0.299993 -126.364) (662.617 50.66 62 175.364) 79 Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) 80 Mesh has 3 solution (non-empty) directions (1 1 1) 81 Boundary openness (1.66252e-17 -2.51027e-15 -1.64139e-16) OK. 82 Max cell openness = 2.35866e-16 OK. 83 Max aspect ratio = 11.1171 OK. 84 Minimum face area = 0.000321178. Maximum face area = 103.224. Face a rea magnitudes OK. 85 Min volume = 7.6199e-06. Max volume = 324.355. Total volume = 1.7993 8e+07. Cell volumes OK. 86 Mesh non-orthogonality Max: 76.2032 average: 17.5263 87 *Number of severely non-orthogonal (> 70 degrees) faces: 17. 88 Non-orthogonality check OK. 89 <<Writing 17 non-orthogonal faces to set nonOrthoFaces 90 Face pyramids OK. 91 Max skewness = 1.00769 OK. 92 Coupled point location match (average 0) OK. 93 94 Mesh OK. 95 96 End However, when I do the simulation in OpenFOAM(I tried OpenFOAMv2306, OpenFOAMv2206 and OpenFOAM-7). The max(mag(U)) keeps rising and finally the case blow up. try `cat log.txt | grep "max(mag(U))"` will show this. I've tried many ways to solve this but still get the problem: 1. I tried the official case settings in OpenFOAM2306, and use laminar to simulate(All the tests are done in laminar mode) 2. I think the intlet and outlet boundary condition matters, the bc in windAroundBuildings are: # | | p | U | # | ---- | ---- | -------- | # | TOP_2D | symmetry | symmetry | # | GROUND_2D | zeroGradient | noSlip | # | WEST_2D | symmetry | symmetry | # | EAST_2D | symmetry | symmetry | # | SOUTH_2D | totalPressure| pressureInletOutletVelocity | # | NORTH_2D | zeroGradient | fixedValue | # | WALLS_2D | zeroGradient | noSlip | and I also tried: # method 1, windAroundBuildings in ofv2306 # | inlet | outlet | # p | zeroGradient | totalPressure # U | fixedVaule | pressureInletOutletVelocity # method 2, simpleCar in ofv2306 # | inlet | outlet | # p | zeroGradient | fixedValue | # U | fixedValue | pressureInletOutletVelocity # method 3, turbulentFlatPlate in ofv2306 # | inlet | outlet | # p | zeroGradient | fixedValue # U | fixedValue | zeroGradient | # method 4, airfoil in ofv2306 # | inlet | outlet | # p | freestreamPressure | freestreamPressure # U | freestreamVelocity | freestreamVelocity # method 5, motorBike in ofv2306 # | inlet | outlet | # p | zeroGradient | fixedValue # U | fixedValue | inletOutlet 3. I tried to use some bounded fvSchemes Code:
divSchemes { default none; // div(phi,U) bounded Gauss linearUpwind limited; // tttt: try-1 div(phi,U) bounded Gauss limitedLinear 1; turbulence bounded Gauss limitedLinear 1; div(phi,k) $turbulence; div(phi,epsilon) $turbulence; div((nuEff*dev2(T(grad(U))))) Gauss linear; //tyj add div(phi,C) Gauss linear; } Code:
p { solver GAMG; smoother GaussSeidel; tolerance 1e-6; relTol 0.01; } pFinal { $p; tolerance 1e-06; relTol 0.01; } "(U|k|epsilon|omega|C)" { solver PBiCGStab; preconditioner diagonal; tolerance 1e-7; relTol 0.0; minIter 2; } "(U|k|epsilon|omega|C)Final" { $U; relTol 0.0; } } SIMPLE { residualControl { p 1e-6; U 1e-6; "(k|omega|epsilon)" 1e-6; } nNonOrthogonalCorrectors 2; pRefCell 0; pRefValue 0; } Any suggestions or solutions to this problem are welcomed !!!It appears that I am unable to solve this particular issue with my current knowledge... |
May 30, 2024, 23:59 |
anyone can help me
Yanjun Tong
Rep Power: 6 |
anyone can help me - -
fluent, openfoam, windaroundobuildings |
dsmcFoam setup | hherbol | OpenFOAM Pre-Processing | 1 | November 19, 2021 02:52 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 09:35 |
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? | Zaphod'sSecondHead | OpenFOAM Running, Solving & CFD | 0 | January 28, 2015 06:17 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 01:02 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
