2D steady state channel with cyclic boundary conditions
Old   May 23, 2024, 10:27
Default 2D steady state channel with cyclic boundary conditions
max mustermann
fuhrmanj is on a distinguished road
I try to implement a 2d steady state, incompressible channel flow with cyclic boundary conditions. The walls are "noSlip" and the inlet and outlet should have periodic boundary conditions (i.e. what flows out of outlet flows in at inlet). The flow should be driven by a "meanVelocityForce" which I implemented in "fvOptions". I am using simpleFoam with all turbulent properties turned off (the plan is to turn them on later, but for now I want to keep it simple). My mesh is generated using blockMesh. I am using two connected blocks because I want to be able to change the geometry of the second block later on to test its impact on the flow in the first block. Checking the mesh with "checkMesh" reports "Ok". I am using simpleFoam. The calculation converges at time=353. The case files are attached. You can execute it via blockMesh -> topoSet -> simpleFoam. I have also attached a picture of the velocity profile.
Here is my question: The picture shows, that the velocity slowly fades/vanishes towards the outlet. Since the inlet-outlet boundary conditions are cyclic and the flow is incompressible, I would expect that the cross-section averaged velocity is conserved, i.e. no fading. I would also expect the velocity profile to be somewhat continuous with no jump. This is clearly not the case. What do you think I am missing? Thank yo so much for your help!
fuhrmanj is offline   Reply With Quote
channel flow, cyclic bc, simple foam, steady state
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 09:03
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
