Discontinuities with the wallHeatFlux at a fluid/solid interface |
May 23, 2024, 05:16 |
#1 | |
Rep Power: 5 |
Hello everyone,
I run a CHT simulation on OF v8 with the chtMultiRegionFoam solver. I use the postProcess utilities to calculate the wallHeatFlux at a fluid/solid interface: Quote:
I noticed that this comportement is also the same with alphat. Alphat is probably used to calcule the wallHeatFlux. The boundary conditions are not very far away of this surface where I calculate the wallHeatFlux but they did not match with the repartition of the discontinuities. So I do not know if it is the boundary conditions or the alpaht file that cause this or anything else. Perhaps someone has faced the same problem ? Do you have any idea ? Thanks in advance, |
alphat, boundaries condition, chtmultiregionfoam, discontinuity, wallheatflux |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Problem with porous flow at multi-material interface with large permeability diff. | Hisham | OpenFOAM Programming & Development | 1 | June 3, 2016 10:51 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
