using a custom boundary condition in OpenFOAM
Old   May 22, 2024, 05:58
Default using a custom boundary condition in OpenFOAM
smhk is on a distinguished road
Hello,I have a written boundary condition for a case and I need to use that for my case.
I go to its folder (the folder is placed in my case folder) and try to compile it by wmake libso but it gives me this following long error:
(Deleted finction error)
/rotatingWallTangentialVelocity$ wmake libso
wmake libso .
Making dependency list for source file rotatingWallTangentialVelocityFvPatchVectorField.C
g++ -std=c++14 -m64 -DLIB_NAME=libRotatingWallTangentialVelocityFvPatchVectorField.so -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam11/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam11/src/OpenFOAM/lnInclude -I/opt/openfoam11/src/OSspecific/POSIX/lnInclude   -fPIC -c rotatingWallTangentialVelocityFvPatchVectorField.C -o Make/linux64GccDPInt32Opt/rotatingWallTangentialVelocityFvPatchVectorField.o
rotatingWallTangentialVelocityFvPatchVectorField.C: In copy constructor ‘Foam::rotatingWallTangentialVelocityFvPatchVectorField::rotatingWallTangentialVelocityFvPatchVectorField(const Foam::rotatingWallTangentialVelocityFvPatchVectorField&)’:
rotatingWallTangentialVelocityFvPatchVectorField.C:109:39: error: use of deleted function ‘Foam::fixedValueFvPatchField<Type>::fixedValueFvPatchField(const Foam::fixedValueFvPatchField<Type>&) [with Type = Foam::Vector<double>]’
  109 |     tangVelocity_(pivpvf.tangVelocity_)
In file included from /opt/openfoam11/src/finiteVolume/lnInclude/fixedValueFvPatchFields.H:29,
                 from rotatingWallTangentialVelocityFvPatchVectorField.H:49,
                 from rotatingWallTangentialVelocityFvPatchVectorField.C:26:
/opt/openfoam11/src/finiteVolume/lnInclude/fixedValueFvPatchField.H:107:9: note: declared here
  107 |         fixedValueFvPatchField(const fixedValueFvPatchField<Type>&) = delete;
rotatingWallTangentialVelocityFvPatchVectorField.C: In member function ‘virtual void Foam::rotatingWallTangentialVelocityFvPatchVectorField::write(Foam::Ostream&) const’:
rotatingWallTangentialVelocityFvPatchVectorField.C:180:15: error: no matching function for call to ‘writeEntry(const char [6], Foam::Ostream&)’
  180 |     writeEntry("value", os);
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/UList.C:226,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/UList.H:490,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/List.H:43,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/wordList.H:42,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/patchIdentifier.H:38,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/polyPatch.H:42,
                 from /opt/openfoam11/src/finiteVolume/lnInclude/fvPatch.H:39,
                 from /opt/openfoam11/src/finiteVolume/lnInclude/fvPatchField.H:47,
                 from /opt/openfoam11/src/finiteVolume/lnInclude/fixedValueFvPatchField.H:54,
/opt/openfoam11/src/OpenFOAM/lnInclude/UListIO.C:85:6: note: candidate: ‘template<class T> void Foam::writeEntry(Foam::Ostream&, const Foam::UList<T>&)’
   85 | void Foam::writeEntry(Ostream& os, const UList<T>& l)
/opt/openfoam11/src/OpenFOAM/lnInclude/UListIO.C:85:6: note:   template argument deduction/substitution failed:
rotatingWallTangentialVelocityFvPatchVectorField.C:180:15: note:   ‘Foam::Ostream’ is not derived from ‘const Foam::UList<T>’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/HashTable.C:645,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/Istream.H:187,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/token.H:495,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/UListIO.C:28,
/opt/openfoam11/src/OpenFOAM/lnInclude/HashTableIO.C:96:6: note: candidate: ‘template<class T, class Key, class Hash> void Foam::writeEntry(Foam::Ostream&, const Foam::HashTable<T, Key, Hash>&)’
   96 | void Foam::writeEntry(Ostream& os, const HashTable<T, Key, Hash>& ht)
/opt/openfoam11/src/OpenFOAM/lnInclude/HashTableIO.C:96:6: note:   template argument deduction/substitution failed:
rotatingWallTangentialVelocityFvPatchVectorField.C:180:15: note:   ‘Foam::Ostream’ is not derived from ‘const Foam::HashTable<T, Key, Hash>’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/FixedList.C:117,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/FixedList.H:380,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/List.C:28,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/List.H:312,
/opt/openfoam11/src/OpenFOAM/lnInclude/FixedListIO.C:35:6: note: candidate: ‘template<class T, unsigned int Size> void Foam::writeEntry(Foam::Ostream&, const Foam::FixedList<T, Size>&)’
   35 | void Foam::writeEntry(Ostream& os, const FixedList<T, Size>& l)
/opt/openfoam11/src/OpenFOAM/lnInclude/FixedListIO.C:35:6: note:   template argument deduction/substitution failed:
rotatingWallTangentialVelocityFvPatchVectorField.C:180:15: note:   ‘Foam::Ostream’ is not derived from ‘const Foam::FixedList<T, Size>’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/UPtrList.C:188,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/UPtrList.H:329,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/PtrList.H:44,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/List.C:29,
/opt/openfoam11/src/OpenFOAM/lnInclude/UPtrListIO.C:32:6: note: candidate: ‘template<class T> void Foam::writeEntry(Foam::Ostream&, const Foam::UPtrList<T>&)’
   32 | void Foam::writeEntry(Ostream& os, const UPtrList<T>& l)
/opt/openfoam11/src/OpenFOAM/lnInclude/UPtrListIO.C:32:6: note:   template argument deduction/substitution failed:
rotatingWallTangentialVelocityFvPatchVectorField.C:180:15: note:   ‘Foam::Ostream’ is not derived from ‘const Foam::UPtrList<T>’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/VectorSpace.H:232,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/Vector.H:44,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/vector.H:39,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/point.H:35,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/pointField.H:35,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/edge.H:40,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/edgeList.H:32,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/PrimitivePatch.H:56,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/primitivePatch.H:35,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/polyPatch.H:43,
/opt/openfoam11/src/OpenFOAM/lnInclude/VectorSpace.C:79:6: note: candidate: ‘template<class Form, class Cmpt, unsigned char Ncmpts> void Foam::writeEntry(Foam::Ostream&, const Foam::VectorSpace<Form, Cmpt, Ncmpts>&)’
   79 | void Foam::writeEntry(Ostream& os, const VectorSpace<Form, Cmpt, Ncmpts>& value)
/opt/openfoam11/src/OpenFOAM/lnInclude/VectorSpace.C:79:6: note:   template argument deduction/substitution failed:
rotatingWallTangentialVelocityFvPatchVectorField.C:180:15: note:   ‘Foam::Ostream’ is not derived from ‘const Foam::VectorSpace<Form, Cmpt, Ncmpts>’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/Field.H:343,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/labelField.H:39,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/primitiveFields.H:37,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/pointField.H:36,
smhk is offline   Reply With Quote
Old   May 22, 2024, 06:05
Continuation of the error:
/opt/openfoam11/src/OpenFOAM/lnInclude/bool.H:60:13: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, bool)’
   60 | inline void writeEntry(Ostream& os, const bool value)
/opt/openfoam11/src/OpenFOAM/lnInclude/bool.H:60:33: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/int.H:38,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/label.H:39,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/UList.H:46,
/opt/openfoam11/src/OpenFOAM/lnInclude/int32.H:75:13: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, int32_t)’
   75 | inline void writeEntry(Ostream& os, const int32_t value)
/opt/openfoam11/src/OpenFOAM/lnInclude/int32.H:75:33: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/int.H:39,
/opt/openfoam11/src/OpenFOAM/lnInclude/int64.H:71:13: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, int64_t)’
   71 | inline void writeEntry(Ostream& os, const int64_t value)
/opt/openfoam11/src/OpenFOAM/lnInclude/int64.H:71:33: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/floatScalar.H:126,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/scalar.H:39,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/zeroI.H:27,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/zero.H:107,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/UList.H:49,
/opt/openfoam11/src/OpenFOAM/lnInclude/Scalar.H:369:6: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, Foam::floatScalar)’
  369 | void writeEntry(Ostream& os, const Scalar value);
/opt/openfoam11/src/OpenFOAM/lnInclude/Scalar.H:369:26: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/doubleScalar.H:127,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/scalar.H:40,
/opt/openfoam11/src/OpenFOAM/lnInclude/Scalar.H:369:6: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, Foam::doubleScalar)’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/longDoubleScalar.H:132,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/scalar.H:41,
/opt/openfoam11/src/OpenFOAM/lnInclude/Scalar.H:369:6: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, Foam::longDoubleScalar)’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/Ostream.H:40,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/OSstream.H:39,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/OStringStream.H:38,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/error.H:51,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/UListI.H:26,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/UList.H:422,
/opt/openfoam11/src/OpenFOAM/lnInclude/verbatimString.H:113:6: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, const Foam::verbatimString&)’
  113 | void writeEntry(Ostream& os, const verbatimString& value);
/opt/openfoam11/src/OpenFOAM/lnInclude/verbatimString.H:113:26: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/keyType.H:41,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/Ostream.H:41,
/opt/openfoam11/src/OpenFOAM/lnInclude/functionName.H:135:6: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, const Foam::functionName&)’
  135 | void writeEntry(Ostream& os, const functionName& value);
/opt/openfoam11/src/OpenFOAM/lnInclude/functionName.H:135:26: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/keyType.H:42,
/opt/openfoam11/src/OpenFOAM/lnInclude/variable.H:133:6: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, const Foam::variable&)’
  133 | void writeEntry(Ostream& os, const variable& value);
/opt/openfoam11/src/OpenFOAM/lnInclude/variable.H:133:26: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/Field.C:28,
/opt/openfoam11/src/OpenFOAM/lnInclude/dictionary.H:889:6: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, const Foam::dictionary&)’
  889 | void writeEntry(Ostream& os, const dictionary& dict);
/opt/openfoam11/src/OpenFOAM/lnInclude/dictionary.H:889:26: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/dimensionedType.H:40,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/DimensionedField.H:43,
                 from /opt/openfoam11/src/finiteVolume/lnInclude/fvPatchField.H:48,
/opt/openfoam11/src/OpenFOAM/lnInclude/dimensionSet.H:435:6: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, const Foam::dimensionSet&)’
  435 | void writeEntry(Ostream& os, const dimensionSet& value);
/opt/openfoam11/src/OpenFOAM/lnInclude/dimensionSet.H:435:26: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
In file included from /opt/openfoam11/src/OpenFOAM/lnInclude/spatialTransform.H:203,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/transformField.H:39,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/transformer.H:45,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/distributionMap.H:134,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/globalMeshDataTemplates.C:28,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/globalMeshData.H:640,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/GeometricBoundaryField.C:29,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/GeometricBoundaryField.H:228,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/GeometricField.H:43,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/GeometricScalarField.H:3,
                 from /opt/openfoam11/src/OpenFOAM/lnInclude/GeometricFields.H:34,
                 from /opt/openfoam11/src/finiteVolume/lnInclude/volFields.H:37,
                 from rotatingWallTangentialVelocityFvPatchVectorField.C:28:
/opt/openfoam11/src/OpenFOAM/lnInclude/spatialTransformI.H:300:13: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, const Foam::spatialTransform&)’
  300 | inline void writeEntry(Ostream& os, const spatialTransform& st)
/opt/openfoam11/src/OpenFOAM/lnInclude/spatialTransformI.H:300:33: note:   no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’
make: *** [/opt/openfoam11/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/rotatingWallTangentialVelocityFvPatchVectorField.o] Error 1
PC:/mnt/k/openfoamorg_pg/Project/rotatingWallTangentialVelocity$
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 09:03
Custom boundary condition in OpenFOAM shinjanghosh OpenFOAM Programming & Development 1 August 26, 2019 06:30
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
