May 19, 2024, 02:58 |
Need help to run francis99 test case
Rep Power: 2 |
Hello everyone.
I'm sort of new in OpenFOAM and trying to learn new things. As a university project I have to run francis99 test case. Now what is francis99 test case? It's a francis turbine that have been studied experimentally and numerically. You can find more information here. Meshes, geometries and case setup are available here. The problem that I cannot understand how to run this case.I want to know how to put meshes and case part together to run the case. Mesh and geometry are available to download from here: https://ntnu.box.com/v/Francis99 & https://www.ntnu.edu/nvks/f99-test-case2 Following photos may help: Case directory: MeshesI know that I must select different meshes) I would be really grateful for your help |
francis99, multiplemesh, openfoam, run |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Merge time folder for pimpleFoam case run in two separate PCs | Ruonin | OpenFOAM Post-Processing | 1 | April 24, 2019 06:59 |
XiFoam Non reactive test case | Stefano Puggelli | OpenFOAM Running, Solving & CFD | 1 | July 9, 2015 02:24 |
DPMFoam case worked perfectly in the first run but crashes in every subsequent run!! | ansubru | OpenFOAM Running, Solving & CFD | 6 | March 17, 2014 04:27 |
how to map results from steady state run to tranient case? | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2010 06:20 |
