epsilonWallFunction and omegaWallFunction G for k omega and k epsilon |
May 18, 2024, 12:45 |
Tom Waits
Rep Power: 8 |
In both the epsilon and omega wall functions, the production term for the models is specified as
if y+ >= y+lam. What do the vertical bars in "|n" and "grad u_f|" mean? What are the corner weights w? And does this mean the production term is turned off for the governing equations for k and epsilon if y+ < y+lam? Why is this done? I can't find any mention of this in the original papers. Many thanks for any help, Tom waits |
May 19, 2024, 09:03 |
1. Vertical lines are magnitude operator. 2. Corner weights are calculated for the corner cells, where contribution of several faces should be accounted. Basically it is 1/number of cell boundary faces. 3. If I unwinded if condition correctly: Code:
if (!lowReCorrection_ || (yPlus(facei) > yPlusLam)) { G0[faceCells[facei]] += cornerWeights[facei] *(nutw[facei] + nuw[facei]) *magGradUw[facei] *Cmu25*sqrt(k[faceCells[facei]]) /(kappa*y[facei]); } There is A Thorough Description Of How Wall Functions Are Implemented In OpenFOAM (https://www.tfd.chalmers.se/~hani/ku...nfoamFinal.pdf) for version 4.0, but implementation of the wall functions did not change much since then. |
Low-Re Modelling | doerschlott | OpenFOAM Running, Solving & CFD | 4 | June 23, 2022 07:53 |
Openfoam Turbulent Car Simulation | meganrw | OpenFOAM Running, Solving & CFD | 0 | July 5, 2021 16:50 |
Turbulent flow around a cylinder with pimpleFoam | Nazim | OpenFOAM Running, Solving & CFD | 2 | May 19, 2020 07:58 |
K-Omega-Epsilon BCs for suction inlet | CFDBro | OpenFOAM Running, Solving & CFD | 0 | March 27, 2018 19:28 |
y+ selection with epsilonWallFunction and omegaWallFunction | wc34071209 | OpenFOAM Running, Solving & CFD | 3 | March 13, 2018 10:20 |
