I create a geometry in salome_meca, simulation a air-water separate channel flow(2D)
Old   May 17, 2024, 05:59
Default I create a geometry in salome_meca, simulation a air-water separate channel flow(2D)
王冠驊
jimmywang5061 is on a distinguished road
This is my geometry file, and I use ideasUnvToFoam to input to my openFoam, this time i use tutorials/interFoam/dambreak/ for my base file.
but my file is too large, so I canot post on here.
this is my geometry:
figure1:https://app.gemoo.com/share/image-an...34073228611584
figure2:https://app.gemoo.com/share/image-an...53043314810880
In my graphic, I want to define the contact surface between the water and air domains as a contact surface (merging two surfaces into one), and define the area marked in red in Figure 2 as a wall surface. How can these steps be achieved in Salome_Meca?
I have tried some attempts on Salome_Meca, after importing into OpenFOAM and entering checkMesh, the result is as follows. I don't think it meets what I want. Could you please provide some suggestions or relevant tutorial video links?
Thank you.
tsefu_ssrshs@SSRSHS:~/SHSs2D(6)$ checkMesh
| \\ / O peration | Version: 2312 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _c39a0f64-20231220 OPENFOAM=2312 version=2312
Arch : "LSB;label=32;scalar=64"
Exec : checkMesh
Date : May 17 2024
Time : 16:57:25
Host : SSRSHS
PID : 12956
I/O : uncollated
Case : /home/tsefu_ssrshs/SHSs2D(6)
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Check mesh...
Time = 0
Mesh stats
internal points: 0
faces: 68470
internal faces: 33530
cells: 17000
faces per cell: 6
boundary patches: 7
point zones: 0
face zones: 0
cell zones: 1
Overall number of cells of each type:
hexahedra: 17000
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
*Number of regions: 3
The mesh has multiple regions which are not connected by any face.
<<Writing region information to "0/cellToRegion"
<<Writing region 0 with 7000 cells to cellSet region0
<<Writing region 1 with 5000 cells to cellSet region1
<<Writing region 2 with 5000 cells to cellSet region2
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
contact_face 70 142 ok (non-closed singly connected)
wall_face 270 546 ok (non-closed singly connected)
inlet 100 202 ok (non-closed singly connected)
outlet 100 202 ok (non-closed singly connected)
front-back 34000 34944 ok (non-closed singly connected)
interface_face 200 404 ok (non-closed singly connected)
side_wall_face 200 408 ok (non-closed singly connected)
".*" 34940 34944 multiply connected (shared edge)
Detected 1 bad edges (possibly relevant for finite-area)
Checking faceZone topology for multiply connected surfaces...
No faceZones found.
Checking basic cellZone addressing...
CellZone Cells Points Volume BoundingBox
water_domain 7000 14342 6.6e-05 (0 0 0) (0.055 0.12 0.01)
Checking basic pointZone addressing...
No pointZones found.
Checking geometry...
Overall domain bounding box (0 0 0) (0.055 0.14 0.01)
Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
Mesh has 2 solution (non-empty) directions (1 1 0)
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (1.69407e-17 -2.09332e-16 -6.82782e-16) OK.
Max cell openness = 1.75744e-16 OK.
Max aspect ratio = 4.80303 OK.
Minimum face area = 7.82208e-08. Maximum face area = 2.72882e-05. Face area magnitudes OK.
Min volume = 7.82208e-10. Max volume = 5.45337e-08. Total volume = 7.4e-05. Cell volumes OK.
Mesh non-orthogonality Max: 0.439253 average: 0.00471218
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.0234518 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
jimmywang5061 is offline   Reply With Quote
twoPhaseEulerFoam confined plunging jet simulation failed ves OpenFOAM Running, Solving & CFD 2 June 17, 2020 06:08
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
simulation with 2 fluids: air and water Rogerio Fernandes Brito CFX 4 March 20, 2008 19:07
Separation phenomenon of water, droplet and air Raymond CFX 0 July 9, 2004 23:59
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 08:04
