OpenFOAM v2106: Running Adaptive Mesh Refinement with AMI present |
Amr Shaalan
Rep Power: 8 ![]() |
I am working on a wind turbine simulation in OpenFOAM using a sliding mesh and I want to also use Adaptive Mesh Refinement. The problem is that once the Adaptive Mesh Refinement is triggered, I get AMI patch weight of 0 and then the simulation crashes. AMI: Patch source sum(weights) min:0 max:1.20617 average:1.00138 I tried to exclude the cells close to the AMI from the refinement by setting a refinement region using topoSet but it did not work (I do not think it is actually selecting the cells I specified) Any help would be greatly appreciated. This is the case folder already meshed: https://drive.google.com/drive/folde...usp=drive_link |
Amr Shaalan
Essentially what I am asking is how to limit AMR to a specific zone and not the whole domain.
Any help is really appreciated ![]() |
dynamicrefinefvmesh |
Problem in meshing and running rotating geometry case with AMI with OF-5 | atul1018 | OpenFOAM Running, Solving & CFD | 0 | April 3, 2024 06:11 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
