April 24, 2024, 13:18 |
MPPICInterFOam can't be execute completely.
Rep Power: 2 |
Hello, I would to get some help. Can someone explain to me why I can't execute this solver. Below is the code. Is there any suggestion to solve this problem?
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _fbf00d6b-20230626 OPENFOAM=2306 version=2306 Arch : "LSB;label=32;scalar=64" Exec : MPPICInterFoam Date : Apr 25 2024 Time : 01:12:44 Host : DESKTOP-GM7974Q PID : 1612 I/O : uncollated Case : /home/shukrie/Run/FirstTime/MPPICInterFoam/twoPhasePachuka nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Reading g Reading hRef Calculating field g.h Constructing kinematicCloud Constructing particle forces Selecting particle force WenYuDrag Selecting particle force gravity Selecting particle force interface Constructing cloud functions none Constructing particle injection models Creating injector: model1 Selecting injection model patchInjection Constructing 3-D injection Choosing nParticle to be a fixed value, massTotal variable now does not determine anything. --> FOAM FATAL ERROR: (openfoam-2306) Requested patch inlet not found Available patches are: 3(base outlet walls) From Foam:atchInjectionBase:atchInjectionBase(const Foam:olyMesh&, const Foam::word&) in file submodels/Kinematic/InjectionModel/PatchInjection/patchInjectionBase.C at line 56. FOAM exiting |
April 26, 2024, 03:47 |
Rep Power: 5 |
Hey!
If you read the end of the log, you can see that OpenFoam tells you what is missing: the patch inlet is mentionned in one of your files, but apparently it does not exist, and you can see a list of available patches in your mesh. Make sure you change the name of the patch used for the injection of particles if that's what you are doing. As a general rule, make sure to read the whole error message, because OpenFoam usually tells you how to fix it |
Reading a sequence of libraries as Execute Commands | Benyounes | Main CFD Forum | 0 | October 14, 2020 05:38 |
Cannot Execute on Demand | Denis | Fluent UDF and Scheme Programming | 6 | June 26, 2018 04:40 |
fatal error while execute on demand... | fatemeh chitgarha | Fluent UDF and Scheme Programming | 1 | July 29, 2013 02:44 |
execute udf in ss & transient simulation | hosseinhgf | FLUENT | 0 | December 1, 2010 08:41 |
error while execute on demand | Anderson | Main CFD Forum | 4 | October 17, 2008 11:48 |
