Turbulence for natural external convection
Old   April 17, 2024, 08:55
Default Turbulence for natural external convection
Gustavo
gushrqcosta is on a distinguished road
Hello. I'm trying to set up a case of natural external convection where a fluid flows around a hot cylinder due only to temperature differences. I have done laminar tests and it worked fine with great results.
Now I wanna add turbulence (by modifying Rayleigh parameters) but I can't figure out how to set up the initial BCs for turbulence.
My professor told me to use k-omega-SST model, but I'm not able to judge the best BCs for the files of k/omega/alphat/nut.
In my case the fluid is initially quiescent (zero velocity) and starts moving only due to the natural convection, but because of this I can't calculate what the initial values for k/omega should be, since the fluid isn't moving at the beggining.
Also, my mesh consists of:
inlet/outlet = patches
superiorPlane/inferiorPlane = symmetryPlane
cylinderWall = wall
frontAndBack = empty
I'm a begginer at OpenFOAM, so I'm sorry for stupid mistakes.
No fvModels present
No fvConstraints present
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5 Foam::fluidThermo::nu() const at ??:?
#6 Foam::RASModel<Foam::compressibleMomentumTransport Model>::nu() const at ??:?
#7 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::compressibleMomentumTransportModel> >, Foam::compressibleMomentumTransportModel>::F2() const at ??:?
#8 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::compressibleMomentumTransportModel> >, Foam::compressibleMomentumTransportModel>::F23() const at ??:?
#9 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::compressibleMomentumTransportModel> >, Foam::compressibleMomentumTransportModel>::correct Nut() at ??:?
#10 ? in "/home/workstation1/OpenFOAM-10/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/buoyantFoam"
#11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12 ? in "/home/workstation1/OpenFOAM-10/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/buoyantFoam"
Floating point exception (core dumped)
gushrqcosta is offline   Reply With Quote
Old   April 17, 2024, 11:40
Alczem is on a distinguished road
Hey,
It looks like a division by 0 occured somewhere!
Try to avoir 0 values in your turbulent boundary conditions (you can use 1e-8 for instance) and in your fluid properties.
Concerning initial values for turbulence, I guess you could estimate the max velocity reached once your convective pattern is established (a few m/s?) and get approximative values for k and omega. Initial values are just that, for the initial steps of the simulation. The turbulent quantities should converge towards realistic values afterwars.
Alczem is offline   Reply With Quote
buoyantpimplefoam, komegasst, natural convection, turbulence
Rotating body with internal and external convection RomuloSc FLUENT 2 October 27, 2017 04:08
Natural convection with or without turbulence model chrisf90 FLUENT 0 June 30, 2016 04:26
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
Appropiate turbulence model for natural convection Diego Peinado FLUENT 0 August 10, 2005 08:24
turbulence modeling for external aerodynamics Charles Renard Main CFD Forum 3 June 27, 2001 08:55
