April 5, 2024, 19:32 |
2D cylinder simulation
aaron LLoyd
Rep Power: 2 |
I am simulating an incompressible external flow 2D circular cylinder. I know that it is a “classical” example but I haven`t been able to find a similar case online to improve my results in order to obtain the most liable/precise simulation.
My Reynolds number is 2.4 x10^4 and I should get a Cd = 1.2. Instead I am obtaining a higher value (1,43 in average). I used snappyHexMesh to generate the mesh and then extrudeMesh, I tried several trials changing layers (number, thickness, conformation) and mesh. In all cases the max value of y+ was <1. I am attaching the results of a simulation in which there were 40 layers and average y+=0.17 and max y+ = 0.32. The code below refers to the 0 folder boundary conditions k, nut, omega, p, U k Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.0294; boundaryField { inlet { type fixedValue; value uniform 0.0294; } outlet { type inletOutlet; inletValue uniform 0.0294; value uniform 0.0294; } left { type symmetryPlane; } right { type symmetryPlane; } top { type empty; } bottom { type empty; } cylinder { type fixedValue; value uniform 1e-10; } } Code:
dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } left { type symmetryPlane; } right { type symmetryPlane; } top { type empty; } bottom { type empty; } cylinder { type calculated; value uniform 0; } } Code:
dimensions [0 0 -1 0 0 0 0]; internalField uniform 164; boundaryField { inlet { type fixedValue; value uniform 164; } outlet { type inletOutlet; inletValue uniform 164; value uniform 164; } left { type symmetryPlane; } right { type symmetryPlane; } top { type empty; } bottom { type empty; } cylinder { type omegaWallFunction; value uniform 164; } } p Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } left { type symmetryPlane; } right { type symmetryPlane; } top { type empty; } bottom { type empty; } cylinder { type zeroGradient; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (14 0 0); boundaryField { inlet { type fixedValue; value uniform (14 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (14 0 0); } left { type symmetryPlane; } right { type symmetryPlane; } top { type empty; } bottom { type empty; } cylinder { type fixedValue; value uniform (0 0 0); } } and controlDict Code:
application pimpleFoam; startFrom latestTime; stopAt endTime; endTime 100; deltaT 0.00001; writeControl adjustable; writeInterval 0.001; purgeWrite 1; writeFormat binary; writePrecision 7; writeCompression no; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.9; functions { #include "forces" #include "forceCoeffs" #include "yPlus1" #include "pressureCoefficient" #include "wallShearStress" #include "Q" #include "wallBoundedStreamLine" } Code:
ddtSchemes { default CrankNicolson 0.9; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss linear; div(phi,k) Gauss upwind; div(phi,omega) Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 1.0; } interpolationSchemes { default linear; } snGradSchemes { default limited 1.0; } wallDist { method meshWave; } Code:
solvers { p { solver GAMG; smoother GaussSeidel; tolerance 1e-6; relTol 0.01; } pFinal { solver GAMG; smoother GaussSeidel; tolerance 1e-8; relTol 0; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0.1; } UFinal { $U; relTol 0; } k { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0.1; } kFinal { $U; relTol 0; } omega { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0.1; } omegaFinal { $U; relTol 0; } } PIMPLE { nCorrectors 2; nNonOrthogonalCorrectors 1; nOuterCorrectors 1; } |
April 6, 2024, 07:21 |
ROIN bin
Rep Power: 7 |
It looks very close, I think we can adjust the calculation area and boundary conditions (such as outlet), and I noticed that you used the built-in post-processing tool to output the coefficient, perhaps test it with force.
April 6, 2024, 12:36 |
aaron LLoyd
Rep Power: 2 |
Thanks for your reply and help: let me try to answer. In forceCoeffs lRef= 0.0272 which corresponds to the diameter of the cylinder,
and Aref= 0.00272 since I set thikness= 0.1 in extrudeMesh. In the postProcessing folder, taking the Cd value at time 0.4, as an example, I have Cd= 1.5499957, and taking at the same time the value of the Total force = Pressure + Viscous in the x direction = 5.0612938e-01. F= 1/2*1.225*14^2*0.00272*1.5499957 which gives a slightly different value: 0.506116759, but this difference seems negligible to me . As for the outlet boundary conditions I just tried to replace in k and omega "type inletOutlet" with "type zeroGradient", but I haven`t seen any change. |
April 10, 2024, 10:21 |
aaron LLoyd
Rep Power: 2 |
Hi, can anyone give me an advice? I would really appreciate it
cylinder, mesh, openfoam, simple |
Simulation of flow around a cylinder in OpenFOAM | martinmat13 | OpenFOAM | 2 | November 17, 2023 08:24 |
[blockMesh] Trouble building blockMeshDict for cylinder in Karman vortex simulation | jdnesbitt | OpenFOAM Meshing & Mesh Conversion | 2 | November 2, 2023 13:09 |
LES - simulation over cylinder. | gu1 | OpenFOAM Running, Solving & CFD | 0 | May 8, 2017 10:34 |
Running a feedback control simulation of the flow around a cylinder | gasagna | OpenFOAM Running, Solving & CFD | 0 | July 16, 2014 11:03 |
modification for rotating cylinder simulation | zonexo | Main CFD Forum | 3 | July 21, 2006 15:24 |
