accesing lagrangian data in run time using coded function object
Old   March 26, 2024, 04:19
Default accesing lagrangian data in run time using coded function object
Franco
otaolafr is on a distinguished road
I am having troubles with 'programming' on a function object of a solver that uses `basicKinematicCollidingCloud`. I have on my mesh a volumetric scalar field I, and I have particlesCloud which are basicKinematicCollidingCloud.
I wanted to use the coded function object, to:
1. recover the I field
2. recover the cloud
3. find the ID of the cell where each particle is located
4. save the evolution of the field I over each particle (so at each time step note the I where the particle is)
5. ideally extend it to make a linear interpolation between the center of the particle and the center of the location of cell center so it is more precise.
but I am struggling to recover the cloud field, I havent found much about using the lagrangian data in run time with exception of this posts:
Access particle data from functionObject
Lagrangian particloe Tracking and getting values back
what I have up to now:
the function object (if I uncomend any of the commends parts the compilation fails):
    fieldLagrangeanVol
        libs            (utilityFunctionObjects);
        type            coded;
        name            fieldLagrangeanVol;
        writeControl    timeStep;
        writeInterval   10;
        // codeInclude
        //     #include "basicKinematicCollidingCloud.H"
        codeWrite
            const auto& banana = mesh().lookupObject<volScalarField>("banana");
            // const auto& t = mesh().lookupObject<basicKinematicCollidingCloud>("cellCloud");
            // const auto* t1 = mesh().findObject<cloud>("cellCloud");
and the cellCloud is defined in the create field:
word cellCloudName("cellCloud");
basicKinematicCollidingCloud cellCloud
    cellCloudName,
    rhoInf,
    U,
    mu,
    g
I am getting the following errors while compiling (if I remove the commend from the corresponding line)
if I active t:
/home/franco/Git/psufoam/Test_Cases/baseCaseWithCyclic/system/controlDict/functions/ILagrangeanVol: In member function ‘virtual bool Foam::ILagrangeanVolFunctionObject::write()’:
/home/franco/Git/psufoam/Test_Cases/baseCaseWithCyclic/system/controlDict/functions/ILagrangeanVol:179:49: error: ‘basicKinematicCollidingCloud’ was not declared in this scope
/home/franco/Git/psufoam/Test_Cases/baseCaseWithCyclic/system/controlDict/functions/ILagrangeanVol:179:78: error: no matching function for call to ‘Foam::fvMesh::lookupObject<<expression error> >(const char [10]) const’
In file included from /usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/objectRegistry.H:759,
                 from /usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/Time.H:45,
                 from /usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/timeFunctionObject.H:44,
                 from /usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/stateFunctionObject.H:52,
                 from /usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/regionFunctionObject.H:56,
                 from functionObjectTemplate.H:38,
                 from functionObjectTemplate.C:29:
/usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:598:13: note: candidate: ‘template<class Type> const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const’
  598 | const Type& Foam::objectRegistry::lookupObject
if it turn on t2;
/home/franco/Git/psufoam/Test_Cases/baseCaseWithCyclic/system/controlDict/functions/ILagrangeanVol:180:49: error: ‘cloud’ was not declared in this scope
/home/franco/Git/psufoam/Test_Cases/baseCaseWithCyclic/system/controlDict/functions/ILagrangeanVol:180:55: error: no matching function for call to ‘Foam::fvMesh::findObject<<expression error> >(const char [10]) const’
/usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:565:13: note: candidate: ‘template<class Type> const Type* Foam::objectRegistry::findObject(const Foam::word&, bool) const’
  565 | const Type* Foam::objectRegistry::findObject
/usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:565:13: note:   template argument deduction/substitution failed:
/home/franco/Git/psufoam/Test_Cases/baseCaseWithCyclic/system/controlDict/functions/ILagrangeanVol:180:55: error: template argument 1 is invalid
In file included from /usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/Time.H:45,
/usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/objectRegistry.H:530:15: note: candidate: ‘template<class Type> Type* Foam::objectRegistry::findObject(const Foam::word&, bool)’
  530 |         Type* findObject
otaolafr is offline   Reply With Quote
function object, lagrangian data, run time
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
error in fireFoam, when running the case wallFireSpread2D zhoubiao1088 OpenFOAM Running, Solving & CFD 9 February 1, 2018 19:45
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
