March 22, 2024, 09:50 |
[olaFlow] an error when I run olaFlow
Yupeng Duan
Rep Power: 4 |
Hi
It is my first time to use olaFlow(under openFOAM v2206), I want to simulate the two box side byside “Jiang, Sheng Chao , W. Bai , and B. Yan . "Higher-order harmonic induced wave resonance for two side-by-side boxes in close proximity." Physics of fluids (2021).” So I change the tut "breakewater", but after I put two box (using the topoSet) the wave has no forward motion: Screenshot from 2024-03-22 19-04-52.jpg remove the box , the wave is nomal : 20240322214808.jpg why this error comes? what should I do to solve this problem? Thanks |
Ansys Installation on Docker Container | mohsen.shiea | ANSYS | 11 | March 14, 2024 12:18 |
Some questions about a multi region case run in parallel | zfaraday | OpenFOAM Running, Solving & CFD | 5 | February 23, 2017 11:25 |
Cannot run phoenix on linux opensuse 13.1 kde | mabal | Phoenics | 0 | June 15, 2014 07:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 12:20 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 13:08 |
